Thread: Avoided collision by jumping a curb, need help!
Results 1 to 14 of 14
  1. #1 Avoided collision by jumping a curb, need help!
    SE Level Member Lionel's Avatar
    Moncton N.B.
    while avoiding an idiot running a red light, I smashed my 04 GT into the curb... and damn... theres some damage. the body is fine, but my passenger side wheel and everything connected to it isn't.
    Busted parts include:
    CV Boot is leaking (the whole shaft popped out when i was removing parts)
    Lower control arm is bent badly
    tie rod is bent
    my tire's belt is broken
    my rim is toast
    the part that you fasten the two bolts to the shock, (dont know what it is called) broke in half.
    now for the question, i got most of these parts off, except the tie rod and the housing where the cv shaft goes into the transmission.
    the tie rod goes into this rubber boot and i dont know where to start to remove it. and when the cv shaft came out, theres this cup looking thing where the three large bearings go into. Do i just leave that there and install the new cv shaft into it?
    I'll take pics if needed. any help woould be great
  2. #2 Re: Avoided collision by jumping a curb, need help!
    Donating Users gtp239's Avatar
    ft myers fl
    you take the cup looking thing out, it is part of the axle the new one will come with one. The thing with the 2 bolts that hold on the strut on is called the spindle.
    1998 gtp fwi, sd headers, overkill,3.4, poly mounts,p&psc
  3. #3 Re: Avoided collision by jumping a curb, need help!
    Charles City, IA
    Pull the boot off the tierod and and you will see where the inner attaches to the rack you will need an inner tierod tool to get it off
    For the Cv put a pry bar in-between the cup and transfer case and pop it out
    SMGPFC Two Nipple General
  4. #4 Re: Avoided collision by jumping a curb, need help!
    Moncton N.B.
    Thanks guys. Another question, the boot just has a tear in it, can I just put another boot on it and salvage the cv shaft?
  5. #5 Re: Avoided collision by jumping a curb, need help!
    Quote Originally Posted by Lionel View Post
    yes you could but im thinking the the whole shaft has to come off anyways to remove the old boot and re install the new boot. if that much stuff is bent/broken, i'd change it just for piece of mind.
    i'd remove the strut too, and make sure its not bent as well. its only 3 more bolts on the top so its worth looking at.
  6. #6 Re: Avoided collision by jumping a curb, need help!
    Jul 2010
    Houston, Texas, United States
    Wow sorry to hear that bro. I'm glad that you going curb hopping kept you safe though.
  7. #7 Re: Avoided collision by jumping a curb, need help!
    the steering knuckle is the part that everything bolts to.
    If you wanted to go used an auto wrecker would sell you most of the suspension for one price.
  8. #8 Re: Avoided collision by jumping a curb, need help!
    Moncton N.B.
    Matt, your avatar is awesome I am so doing that one day lmao.
    So my cv shaft was busted under the boot, had to replace that. Also when I cut my wheel my tie rod end has a bit of play, I'm guessing it needs replacing? Aand when I cut my wheel I hear a rubbing noise, I sourced it to my strut mount, the nut and metal plate turn with the shock. And it seems the rubber under the plate is squished compared to the other side.
    Would tightening the nut stop it from turning? Or is something ceised in there? I appreciate all the help guys!
    Lg
  9. #9 Re: Avoided collision by jumping a curb, need help!
    Kansas
    That sucks dude. I had an event with a curb a couple weeks ago. Did you take pics? Surprised no one has asked for pics yet.
  10. #10 Re: Avoided collision by jumping a curb, need help!
    GT Level Member RegalGS98s's Avatar
    NJ
    Sorry to hear about that, at least you and the body of the car are good. For the inner tie rod, if you replace it instead of the whole rack, this is the tool I recommend: Inner Tie Rod Removal Set I replaced the inner tie rod on my GTP using vise-grips and alot of muscle. After that I got the tool and used it on the Buick and it was so many times easier. You do have to grind one of the adapters a little bigger to fit our cars. Also be sure to loosen the crush lock on the inner tie rod. If you have 200k miles like I do on the Regal, you may decide it's time to just replace the whole rack. Plus, it may be damage as well from the crash. Advance Auto with using their coupon codes was the cheapest I found for the steering rack. $135 shipped. Think was a little more for the GTP.
    SMGPFC #0330 - 3.25, Intercooled, Custom Tune, 1.84rr, LS6 Springs, roller timing chain, SLP Headers, Borla Exhaust, built Trans, B&M Trans Cooler, home cut poly uppers, gapless rings, N* TB, Ported heads.
    Soontocome: CAM?, Custom modified M112, home poured Poly Engine and Trans mounts
  11. #11 Re: Avoided collision by jumping a curb, need help!
    Brownsburg
    Ouch, had a similar incident but didn't involve another car I ended up cracking a rim, cutting a tire, bent tie rods. Got lucky on the cv, lca however. It's a lot of work and really sucks. Personally w the amount of force it takes to damage a kncukle and mangle a control arm I'd probably replace all of that. Struts I'm not well versed in. If it were my car and the knuckle were damaged that badly (we haven't seen pics here so have to assume the worst) I would probably remove the strut to make sure it was not bent as well. Seems like it would be very unlikely it came out out of this unscathed. How old are strut and mounts? If original this may be a good time to upgrade if the funds are available
  12. #12 Re: Avoided collision by jumping a curb, need help!
    Moncton N.B.
    Unfortunately I didnt take any pics, I should have.
    I already took off my inner tie rod with that special tool.
    The strut seems ok, I think I just damaged my strut mount, plus i hear clicking noise when i turn my wheels.
    And yes my steering knuckle took a beating, it snapped in half basically where the caliper attaches to it i could see the bolt, and it exposed my wheel bearing.
    I'm going to replace the strut mount and see what happens. I'm just going to replace my outer tie rod, it seems to move too easily.
    Thanks for all the feedback guys.
  13. #13 Re: Avoided collision by jumping a curb, need help!
    SE Level Member Curt7's Avatar
    Jul 2011
    Ontario
    Was the sway bar damaged at all?
    2003 Grand Prix GT
  14. #14 Re: Avoided collision by jumping a curb, need help!
    Moncton N.B.
    No, the sway bar link was bent pretty bad but the sway bar is fine, the bushing is good and its not bent.
  1. Musta been one hell of a curb
    By Explicit_Spade in forum Off Topic Discussion
    Last Post: 05-27-2011, 01:12 AM
  2. DIY curb rash repair on clearcoat rim.
    By Specter GXP in forum Tires & Wheels
    Last Post: 01-28-2011, 11:27 AM
  3. Just not jumping like it should!
    By BigmikesSilverBullet in forum General Tech Discussion
    Last Post: 04-29-2010, 12:52 AM
  4. ice + curb = fail
    By DaytonaGTP in forum Off Topic Discussion
    Last Post: 12-24-2009, 05:59 PM
  5. Gears jumping around?
    By WhiteGT in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-18-2008, 09:10 PM
