Thread: metal grind/rattle when hvac system is off
Results 1 to 4 of 4
jluca metal grind/rattle when hvac... 11-01-2010, 11:48 AM
BillBoost37 Re: metal grind/rattle when... 11-01-2010, 12:23 PM
shawngtp Re: metal grind/rattle when... 11-01-2010, 12:27 PM
Robert Sherman Re: metal grind/rattle when... 07-02-2011, 06:18 PM
  1. #1 metal grind/rattle when hvac system is off
    SE Level Member jluca's Avatar
    New York
    Getting a weird rattle/grind noise coming from the front of the car when the hvac system is off. sound goes away if i turn the sytem on. anyone had a smiliar issue?
    2002 GTP
  2. #2 Re: metal grind/rattle when hvac system is off
    That'll either be a need to have your AC compressor clutch spacing adjusted or you'll need a new compressor.
  3. #3 Re: metal grind/rattle when hvac system is off
    Nov 2009
    Grand haven
    This ^^^
  4. #4 Re: metal grind/rattle when hvac system is off
    Fulton, MS
    I'm having the opposite problem, but intermittent; get a grinding noise when the system is on, with metal shavings around the compressor pulley. Can you tell me more about adjusting the compressor clutch spacing?
  1. Strange grind, timing chain?
    By ninnyGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-23-2009, 05:08 PM
  2. Grind/moan from tranny
    By 07CrimsonGT in forum General Tech Discussion
    Last Post: 09-14-2009, 10:27 PM
  3. Metal Clip
    By Red97GPGT in forum Brakes/Suspension/Chassis
    Last Post: 03-24-2009, 09:00 PM
  4. Metal Shavings
    By GTPluv in forum Off Topic Discussion
    Last Post: 04-02-2008, 11:53 AM
