Thread: Thought cruise wont work with abs light on?
Results 1 to 8 of 8
  1. #1 Thought cruise wont work with abs light on?
    wi
    My abs and tcs lights are both on and I havent found the problem yet, Tried a new/used moduel, pump is working, and replaced both switches that contact the brake under the dash. All speed sensors seem to read fine when hooked to the scanner.
    For some reason my cruise will work some day's and other's it wont. From what I red, if these light are on the cruise wont work??
    Any help or thing's to check would be great because im stumped.
  2. #2 Re: Thought cruise wont work with abs light on?
    looks fast.... its slow:) beckys2000gt's Avatar
    Nov 2009
    stoystown, pa
    my abs and tcs light has been on for 6-9 months now, and my cruise works fine......
  3. #3 Re: Thought cruise wont work with abs light on?
    wi
    I wonder why it only works every once in awhile then.
  4. #4 Re: Thought cruise wont work with abs light on?
    Nov 2009
    stoystown, pa
    its probably would cruise control goin bad or something, like i said, my lights have been on forever, and cruise works fine every day
  5. #5 Re: Thought cruise wont work with abs light on?
    wi
    whats most common to go out on the cruise control that would cause it to do this?
  6. #6 Re: Thought cruise wont work with abs light on?
    Nov 2009
    stoystown, pa
    not sure, i never had to deal with this stuff....... thats a question for billboost
  7. #7 Re: Thought cruise wont work with abs light on?
    third brake light. i think if a bulbs burned out it stops the cruise control
  8. #8 Re: Thought cruise wont work with abs light on?
    wi
    Im just wondering if the front moduel under the hood goes out or the switch on the steering colum. It's not the third brake light because sometimes it work's
  1. Cruise control does not work, suggestions??
    By crbquist in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-10-2011, 06:49 PM
  2. Brake light, turn signal, cigarette lighter wont work
    By dlouis30 in forum Introductions/Noob Questions
    Last Post: 03-02-2010, 10:07 PM
  3. 06 GP, cruise doesnt work, fuse good, HELP!!!
    By Schooter in forum General Tech Discussion
    Last Post: 08-13-2009, 07:56 PM
  4. Cruise control and AC won't work
    By ala17 in forum General Tech Discussion
    Last Post: 06-28-2009, 11:47 PM
  5. Cruise dosen't work?
    By crywolf in forum General Tech Discussion
    Last Post: 11-13-2008, 01:03 PM
