Thread: Ideas on Misfire
Results 1 to 6 of 6
  1. #1 Ideas on Misfire
    GTX Level Member tayl5645's Avatar
    Jul 2010
    Michigan
    Ok guys its been getting kinda bad lately. Usually get misfires when I start my car between 2-6 (aerforce readings). Then periodically throughout a drive misfires will pop up usually no more then 2 at a time. I have gotten the code for random misfires already and from what the aeroforce reads it is mainly cylinder 3 and 4. I did at one point have a cat eff light (still needs fixed) however, Im not bogging under two heavy of accels. Usually the misfires creep up after I get out of the throttle which again would make me believe its not load related. All those techies out there that have ideas that I can check out. Plugs and wires changed about 200 miles ago in an attempt to fix the problems
    2005 GTP Grey
    Custom built Open cone intake, 15% tints all the way around, 7" touchscreen DVD player
  2. #2 Re: Ideas on Misfire
    Grand Island, Nebraska
    What plugs/wires are you using and what did you gap them to? are you positive the wires are on the correct cylinders?
  3. #3 Re: Ideas on Misfire
    Jul 2010
    Michigan
    Issues were the same before Tune up so I would rule out anything to do with the plugs and wires.
    2005 GTP Grey
  4. #4 Re: Ideas on Misfire
    Just trying to get some info.
  5. #5 Re: Ideas on Misfire
    Jul 2010
    Michigan
    Not sure on plugs and wires installed by my friends dad (my free mechanic/ owns his own shop) my guess is they would be stock replacements nothing upgraded gapped to specs.
    2005 GTP Grey
  6. #6 Re: Ideas on Misfire
    swap 2 coils around and see if it follows
  1. HELP PLEASE! Misfire at 5
    By bbfanatic23 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-02-2013, 05:34 PM
  2. 04 GTP misfire..a fun one..
    By silly34 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-08-2011, 11:42 AM
  3. tattoo ideas for my cast! post your ideas!
    By putskijr in forum Off Topic Discussion
    Last Post: 07-11-2010, 04:53 PM
  4. Cylinder #1 misfire and random cylinder misfire
    By whodat79 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-21-2010, 07:16 AM
  5. misfire bad
    By YoungGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-11-2008, 04:39 PM
