Thread: Which pulley?
Results 1 to 14 of 14
  1. #1 Which pulley?
    SE Level Member Iwannagofast's Avatar
    Arkansas
    Ok I have done some research and I think I have most of the mods planned out but not quite.
    I was thinkin speed daddy headers with no cat no rear 02 and a cutout with stock catback.
    auto lite 104s and 160 tstat
    I already have a homemade intake
    A PCM(not sure exactly which one)
    Would this be enuf to run a 3.3 or even a 3.25 pulley?
    About how much power would this setup make on the motor?
    This is an 04 impala ss btw
  2. #2 Re: Which pulley?
    Charles City, IA
    change that to a 180 tstat or leave it stock then you should be ok for a 3.4/3.5
    SMGPFC Two Nipple General
  3. #3 Re: Which pulley?
    Grand Island, Nebraska
    Yea its highly unlikely you could get a 3.3 without some valvetrain work/intercooler.
    You will need a custom in-car tune at that level.
  4. #4 Re: Which pulley?
    Omaha, NE
    No, it would not be enough.
  5. #5 Re: Which pulley?
    Arkansas
    ok well about how much power with that setup and a 3.4
    also how much power with that setup plus the short stack and a 3.25 or 3.3?
    Im sure these are some of the questions everybody gets tired of seeing but im new whole modding of l67s and what not.....you could ask me about a 5.0 mustang all day though.
  6. #6 Re: Which pulley?
    If you want to know how much power get it dyno tuned. 2 birds with one stone.
  7. #7 Re: Which pulley?
    Omaha, NE
    Perhaps you should search or read threads on modding, like this one.
    http://www.grandprixforums.net/safel...car-17482.html
  8. #8 Re: Which pulley?
    Arkansas
    Well when i get to that point im sure i will but right now i was just tryin to figure out what it would take to get to a certain power level.
  9. #9 Re: Which pulley?
    Arkansas
    Yes that thread is where I got the list of mods in the first post....I was just wondering about hp numbers and how much im gonna have to spend to get to where i want to be
  10. #10 Re: Which pulley?
    Omaha, NE
    What is that power number you're trying to hit?
  11. #11 Re: Which pulley?
    Out West
    Quote Originally Posted by Iwannagofast View Post
    Think 3.4, and that's with a really good tune.
  12. #12 Re: Which pulley?
    MA
    you want more power though.. youd prolly be better off running your 3.8 pulley with more timing.
    SMGPFC Member #9
  13. #13 Re: Which pulley?
    Arkansas
    I was thinking slightly under 300 to the wheels 330ish on the motor.
  14. #14 Re: Which pulley?
    Troy OH
    probably not without a cam. also, leave your rear O2, your pcm uses that for fuel readings. although it's not as important as the first one, i'm sure it still makes a difference. i second the 180 thermostat and a 3.4". that'll put you around 270 give or take at the crank, getting close to 240 at the wheels
