Thread: Very annoying squeak
Results 1 to 4 of 4
  1. #1 Re: Very annoying squeak
    whens the last time you change the serpentine belt?
    it sounds like the your power steering is letting you know the belt is shot.
  2. #2 Re: Very annoying squeak
    St. Louis
    I'd start with the mention above to the belt.
    Then if that checks out maybe check the front struts. It could be worn out strut mounts. Open the hood and take a look at where the top nut is on the strut. Now, push down on the fender and get the car to bounce up and down a bit. Is that big rubber bushing pushing upwards? If so, that may cause it too.
    Stock struts on a 99 are junk by now and need to be changed, along w/ the strut mount and springs.
  3. #3 Re: Very annoying squeak
    Jun 2011
    Hilliard Ohio
    Actually it was the metal clip holding in the pads on the brakes, they extended out too far and when you turned it scraped the inside of the calipers. Never really noticed for some reason . I'm retarded thanks guys!
  1. Top 10 Most Annoying Things Other Drivers Do
    By rynoman03 in forum Off Topic Discussion
    Last Post: 07-03-2013, 03:01 PM
  2. This is annoying!!!!
    By IR II IP IDEATH in forum Off Topic Discussion
    Last Post: 09-21-2010, 12:19 PM
  3. Whats most annoying?
    Last Post: 08-23-2010, 05:27 PM
  4. Stop with the annoying ****!!!!!
    By IrishNation24 in forum The Rant Forum
    Last Post: 11-26-2009, 10:21 PM
  5. Annoying Problem
    By fatjoe in forum Audio, Security & Visual Electronics
    Last Post: 04-17-2009, 07:17 AM
