Thread: rough idle/ engine chugging and struggle
Results 1 to 11 of 11
  1. #1 rough idle/ engine chugging and struggle
    detroit
    engine chugs when in low rpms between while idling and when taking off it struggles to go anywere and takes off slower then usual but is fine when driving down the road.. theres no engine light on and ive read a few posts about it being the MAF but it doesnt seem to work for others.. i was wondering if it could be the plugs or wires
  2. #2 Re: rough idle/ engine chugging and struggle
    do a tune up.
    plugs, wires, clean the maf with maf cleaner, take the throttle body off and all the sensors on it and clean it out really good.
  3. #3 Re: rough idle/ engine chugging and struggle
    looks fast.... its slow:) beckys2000gt's Avatar
    Nov 2009
    stoystown, pa
    possibly change your fuel filter as well........going through that **** with my monte carlo right now, lol
  4. #4 Re: rough idle/ engine chugging and struggle
    SE Level Member justinmc84's Avatar
    Jun 2011
    colorado
    I have similar problems (like 3 threads down on this page) and I put on new plugs, wires, and MAF sensor and I'm still having issue. My next 2 guesses are fuel filter (20 bucks) or catalytic converter (200 bucks for a bolt in magnaflow high flow cat). I don't have a jack though so I can't get underneath the car.
  5. #5 Re: rough idle/ engine chugging and struggle
    detroit
    i changed the fuel flter and that didnt help i was going to try the MAF cleaner but when i checked for dirt i didnt see anything to my eye if that didnt work i was going to try plugs
  6. #6 Re: rough idle/ engine chugging and struggle
    Quote Originally Posted by jordan61488 View Post
    change the plug wires too, and you could have a clogged cat possibly.
    how high are your miles?
  7. #7 Re: rough idle/ engine chugging and struggle
    Jun 2011
    colorado
    If you've already switched out the fuel filter I'd say its the cat that you need to replace. I'm at the same point with my car and can't seem to get anyone to reply to my thread anymore.
  8. #8 Re: rough idle/ engine chugging and struggle
    Donating Users kyleinkman's Avatar
    May 2011
    canada
    crank shaft sensor. had similar problem replaced mine and it runs like a dream again
  9. #9 Re: rough idle/ engine chugging and struggle
    St. Louis
    I wouldn't go through the hassle of replacing the CPS yet considering we don't even know the maint. history of this car. Plugs and wires are cheap and probably need to be done anyway. If his car isn't dropping the tac to 0 while driving or just outright dying on him then I wouldn't suspect the CPS just yet.
    This sounds more to me like a tune-up is needed. Then we can go from there. It could be a million things. Vac leak, bad PCV, clogged cat, bad MAF, etc.... Get the basics done. If you ask yourself "When was the last time xyz was changed" and the answer comes back as "I don't know", then it's time to change it.
    OP- You say you looked at the MAF and it didn't look dirty? Man you have some good eyes cause those wires are pretty thin. I would go ahead and clean it anyway. Just eliminates a common cause of these cars running poorly, especially with higher mileage. I thought mine was clean too, but then went and cleaned it and it ran great. Took all of 10 min. including finding where the heck I put my tamper-proof torx bits, lol..
  10. #10 Re: rough idle/ engine chugging and struggle
    Pennsylvania
    Quote Originally Posted by FordMan77 View Post
    $10, 10 minutes, 10x better throttle action, increased gas mileage... can't go wrong. Heck, I clean mine like once a month.
  11. #11 Re: rough idle/ engine chugging and struggle
    detroit
    Ended up bein a ignition module.. I would reccomend taking it in rather then spending 500 dollars on parts that u dont need
  1. engine rough shaking/ chugging vibration
    By jordan61488 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-26-2011, 02:58 PM
  2. engine idle rough, acceleration bad
    By ksredryder in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-30-2010, 08:30 AM
  3. Rough Idle
    By PTGsDaytona500GTP in forum General Tech Discussion
    Last Post: 09-01-2010, 10:48 PM
  4. rough idle after engine replacement
    By almighty in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-18-2009, 07:55 PM
  5. rough idle after engine swap
    By almighty in forum Engine
    Last Post: 11-18-2009, 06:25 PM
