Thread: lower intake manifold job
Results 1 to 14 of 14
  1. #1 lower intake manifold job
    GTX Level Member bps02gtp's Avatar
    Nov 2010
    Illinois
    What else should I do while I do it? Coolant elbow, thermostat housing gasket, what else????
  2. #2 Re: lower intake manifold job
    Donating Users Kejross's Avatar
    Feb 2010
    Oklahoma City, OK
    Quote Originally Posted by bps02gtp View Post
    That's about it besides a oil change and coolant flush shortly after your done. Don't know that I would mess with the tstat gasket either but its cheap enough and easy enough I guess. And I assume you know to get the upgraded aluminum LIM gaskets and not the plastic ones?
    SOLD-98 4dr GTP, l32 Swapped, IS2 heads, IS3 cam, S2 intercooler, S3 FMHE, E85, 65# inj, N* TB w/LQ4, OBX Headers, Borla catback, 3.0 zzp mps, lc-1 wideband, HP Tuners, PRJ wires, FWI, Lowered. 04 GTO M6, 07 Grand Prix LS4 powered GXP. 98 V6 GMC SWB, exhaust, custom intake. 09 HHR (Wifes)
  3. #3 Re: lower intake manifold job
    Nov 2010
    Illinois
    no i dont know. how and where? at autozone they have two different fel-pro kind. one thats rubber and plastic and the other is some fancier kind that comes with o-rings for the injectors, some other o-rings and the tstat gasket.
  4. #4 Re: lower intake manifold job
    Nov 2010
    Illinois
    u talkin about from zzp?
  5. #5 Re: lower intake manifold job
    Grand Rapids, MI
    no, just get them from rockauto.com or something. i think most parts stores have them as well.
    just get the fel-pro kit, your coolant elbows, and make sure they haz everything you need like all the little o-rings and what not.
  6. #6 Re: lower intake manifold job
    Nov 2010
    Illinois
    ok i see the one that comes with all the o-rings and stuff. but it doesnt say if its aluminum or not. thats y i didnt get it from autozone. so the fel pro "permadry" is the aluminum one?
  7. #7 Re: lower intake manifold job
    Grand Rapids, MI
  8. #8 Re: lower intake manifold job
    Nov 2010
    Illinois
    i just got it from rock auto. i needed the supercharger gasket and after shipping and handling i saved 4 dollars. thanks a lot for telling me about that website.
  9. #9 Re: lower intake manifold job
    Grand Rapids, MI
    you need the tb gasket as well if you take it off. you might also consider doing valve cover gaskets at the time. and don't forget coolant elbows.
    there's also a discount code for that site, you do know that?
  10. #10 Re: lower intake manifold job
    valve cover gaskets and the grommets.
  11. #11 Re: lower intake manifold job
    Grand Rapids, MI
    thank you
    grommets.
  12. #12 Re: lower intake manifold job
    Nov 2010
    Illinois
    no i did not know that. too late i already bought it. i was thinkin about doin valve cover gaskets and grommets. might as well i guess since everythings is off
  13. #13 Re: lower intake manifold job
    Grand Rapids, MI
    yeahhh it was a 5% discount i coulda gave you the code
    yeah, if you wanna do vc just go to autozone they haz felpro and u can get grommets there too. i just did mine on rockauto cus i was penny pinching everything.
  14. #14 Re: lower intake manifold job
    Nov 2010
    Illinois
    yeah i kinda need to do that too. these gaskets for these engines are a little pricy compared to others i have done.
  1. the best lower intake manifold gasket?
    By bps02gtp in forum General Tech Discussion
    Last Post: 06-24-2011, 05:04 PM
  2. lower intake manifold gasket
    By backinblackgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-03-2010, 09:26 PM
  3. Lower Intake Manifold
    By stlmo_gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-14-2009, 10:44 PM
  4. Lower intake manifold
    By FuglyGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-06-2009, 10:40 AM
