Thread: a buncha questions
Results 1 to 10 of 10
Threaded View
  1. #1 a buncha questions
    GT Level Member mezzoni's Avatar
    Nov 2009
    Milford, CT
    1. is a gasket set necessary when installing speed daddy headers?
    2. what gaskets should be replaced when doing a top swap? can any be re-used?
    3. what bolts can be reused on a top swap from an l67? which should be replaced?
    4. do you need a top swap wiring harness when doing a top swap (that $35 one on zzp)?
    5. if your car is tuned for a 3.6 but your running a 3.5 on a top swap there will be a greater chance of knock correct? also can i run a 3.5 with just headers intake plugs wires and tstat on a top swap?
    6. are drilled and slotted rotors even worth the price if your not getting a bigger size?
    7. does having too powerful of an amp affect speakers in a negative way?
    8. whats your favorite brand of speaker?
    (im in very much of a learning mood tonight lol)
    2006 pontiac G6 GT coupe - the daily
    2001 pontiac trans am WS6 - pacesetter headers, slp exhaust, diablo sport tuner, ported throttle body, ported MAF, SLP intake lid, B&M shifter, UMI panhard bar, lowered on koni's
  1. Few Questions :)
    By GrandPrixSE in forum General Tech Discussion
    Last Post: 06-06-2010, 08:20 AM
  2. Alky Questions & Other Related Questions.
    By rynoman03 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-22-2010, 07:57 AM
  3. Car questions
    By Panther427 in forum 5.3L V8 (LS4)
    Last Post: 07-18-2009, 12:01 AM
  4. A few questions
    By Shaunk in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-24-2009, 09:36 PM
  5. two questions
    By DWosik13 in forum Off Topic Discussion
    Last Post: 08-03-2008, 02:33 AM
