Thread: audio buttons on 98 gtp steering wheel question
Results 1 to 5 of 5
  1. #1 audio buttons on 98 gtp steering wheel question
    Jun 2011
    Sheboygan
    The buttons on the left side of the wheel were not working, so I pulled the butons out of the wheel to see the connector was not connected. How in the world to you connect the connector, there is very little play, I know how to plug it in, but the wire is so short, it wont pull out far enough to connect the buttons again? Any thoughts?
    Thanks in advance
  2. #2 Re: audio buttons on 98 gtp steering wheel question
    Yoga city
    Luck my friend had same issue I put some cardboard behind it and pushed so good luck
  3. #3 Re: audio buttons on 98 gtp steering wheel question
    Denver
    Pull the cord - it will give you adequate play.
    I've had these buttons off and on many times - they're kind of a pain, but not that bad.
  4. #4 Re: audio buttons on 98 gtp steering wheel question
    The wires are taped under the airbag. Like mentioned if you gently tug, you should be rewarded. If not.. needle nose pliers.
  5. #5 Re: audio buttons on 98 gtp steering wheel question
    Jun 2011
    Sheboygan
    thanks guys, I will give it a try
  1. steering wheel audio controls
    By 97gmgtp in forum General Tech Discussion
    Last Post: 12-01-2010, 01:26 PM
  2. audio steering wheel controls
    By mlinville11 in forum Shops and Community Heroes
    Last Post: 07-15-2009, 10:08 AM
  3. Reinstalling steering wheel buttons - How??
    By BlownBigBlock in forum Audio, Security & Visual Electronics
    Last Post: 05-08-2009, 12:01 PM
