Thread: Which is best?
Results 1 to 12 of 12
  1. #1 Re: Which is best?
    GTP Level Member VinnieGTP's Avatar
    Las Cruces, NM
    The way to stay cooler is to a 30/70 water/coolant mix in the summer. Just remember to add more coolant before the first freeze.
  2. #2 Re: Which is best?
    PA
    Quote Originally Posted by VinnieGTP View Post
    FWIW, you would want a 30/70 coolant/water mix. The more water you run, the better in the summer.
    I knew what you mean, I think you just got your mixes all worded up.
    2001 GSE
  3. #3 Re: Which is best?
    Las Cruces, NM
    Quote Originally Posted by Zef_66 View Post
    That's what I meant, it was late.
  4. #4 Re: Which is best?
    GTX Level Member Andrew_99GTP's Avatar
    New Salem, ND
    I am running straight water for now. I haven't taken the time to flush the system and add straight green.
    Red 2dr 99 GTP"Old" Z7 t66, A/A IC'd, Custom Heads, 65# Inj, ST2 Cam, Meziere Elec Pump, JP Double Roller(with machined crank gear), Plogs, PLX W/B, Powrtuner SOLD
    "New" 2007 Duramax ccsb with a few mods
