Thread: winshield molding
Results 1 to 2 of 2
  1. #1 winshield molding
    pennsylvania
    So when i bought my car the top left part of my windshield molding is almost completely up. How easy is it to replace this molding
  2. #2 Re: windshield molding
    SE Level Member jmt455's Avatar
    SE Michigan
    FSM says:
    "Windshield Reveal Molding Replacement
    The windshield reveal molding is an applied molding design separate from the window . The reveal molding is bonded to the windshield and may be bonded to the body. The reveal molding may be replaced with the windshield as an assembly, or the reveal molding may be available as a separate service part. Refer to Urethane Adhesive Installation of Stationary Windows .
    The images show the glass bonded with a urethane sealer to the windshield opening pinch weld flange, then the acoustic seal and finally the decorative molding."
    The only instructions regarding the molding:
    "Install the new windshield acoustic strip (1) to the windshield (2), if equipped or damaged. The acoustic strip aids in reducing noise.
    If installing a new window reveal molding, start in the center and work toward each end pressing firmly into place."
    HTH...
    83 Bonneville wagon
    08 G8 Base
  1. molding help
    By wide open 97 in forum Visual/Body Modifications
    Last Post: 01-07-2011, 03:21 PM
  2. winshield washer hose
    By JoeC9107 in forum General Tech Discussion
    Last Post: 09-14-2010, 06:44 PM
  3. rubber seal around winshield
    By Tyler_06 in forum Visual/Body Modifications
    Last Post: 07-23-2010, 07:04 PM
  4. first gauge molding job
    By 00grandam in forum Visual/Body Modifications
    Last Post: 01-26-2010, 05:27 PM
  5. winshield wiper help
    By RedLedbetter in forum General Tech Discussion
    Last Post: 04-07-2009, 06:48 PM
