Thread: 97 gtp window offtrack
Results 1 to 5 of 5
  1. #1 97 gtp window offtrack
    pennsylvania
    Well when i roll up my passanger window it goes fine till about half way then slows down and goes out of the track enough where it goes to far up on the window to where it hits my ventshades. and then there is a gap where rain gets in. how do i fix this problem?
  2. #2 Re: 97 gtp window offtrack
    Waukesha, WI
    take the door panel off and straighten the run channels that the window rides on.
    RayRay
    92 Turbo miata
    71 bagged lemans wagon
    02 lexus is300
  3. #3 Re: 97 gtp window offtrack
    you may have the same problem as this member did, any way you look at it, your going to have to remove the door panel and check it out, http://www.grandprixforums.net/repla...elp-47746.html
  4. #4 Re: 97 gtp window offtrack
    pennsylvania
    what do you use to straighten the run channels
  5. #5 Re: 97 gtp window offtrack
    any type of pliers will work given the space and angles you have to work with.
  1. Window fog. How to get rid of?
    By Toofastgs in forum General Tech Discussion
    Last Post: 12-10-2013, 12:49 PM
  2. Sunroof offtrack?
    By Jrodbrown58 in forum General Tech Discussion
    Last Post: 10-03-2011, 01:30 AM
  3. My window goes up but not down
    By wesjim in forum Introductions/Noob Questions
    Last Post: 06-11-2010, 04:01 PM
  4. Window help
    By ptnothere in forum General Tech Discussion
    Last Post: 06-09-2010, 12:21 AM
  5. Window Problem (Front Driver Side Window)
    By trogdor007 in forum General Tech Discussion
    Last Post: 06-03-2009, 09:22 PM
