Thread: Sunroof offtrack?
Results 1 to 3 of 3
  1. #1 Sunroof offtrack?
    SE Level Member Jrodbrown58's Avatar
    Hawesville, KY
    Hey guys, today I was using my sunroof and it usually works fine other than squeaking a little, but today when i went from having it all the way open I was going to raise it up. well when it closed and was about to work its way up it stopped so i put a little pressure on the back-end of it bc it has happened before and i done that and worked perfectly but today i heard a noise not really a pop or crack so i dont think anything is broken just off track and anyways it wont raise up and it will open all the way back after holding the button for a while but when u try to close it nothing happens you just hear the track move then u have to close it manually. is there someone that could give me some advice on how to fix this?
    '95 Grand Prix 3.1L V6
  2. #2 Re: Sunroof offtrack?
    Hawesville, KY
    Well today I was working on my sunroof problem and I resolved one problem with the front of the sunroof moving too much up and down but it's still off track and I'm not sure of the easiest way to take some of the sunroof out so that 1) I can see what could be going on and then 2) I can take the sunshade out to reglue the liner back on...if anyone could help at all with this I would appreciate it. If I can't fix it though I'm thinking about just buying a new sunroof once I can afford it
  3. #3 Re: Sunroof offtrack?
    Oct 2011
    Fort Wayne
    i have the same issue i really want it fixed i just dont know where to begin
  1. Can anyone with a 99-03 GP with a sunroof...
    By BwolfGT in forum Off Topic Discussion
    Last Post: 03-02-2010, 02:11 PM
  2. Is Sunroof the same 97-03?
    By Tfreeds in forum General Tech Discussion
    Last Post: 02-14-2010, 03:22 PM
  3. Sunroof?
    By mike171562 in forum General Tech Discussion
    Last Post: 08-26-2009, 12:21 PM
  4. Sunroof
    By K1J1E2 in forum General Tech Discussion
    Last Post: 03-12-2009, 11:43 PM
  5. Help with sunroof!
    By kbwent in forum General Tech Discussion
    Last Post: 02-22-2009, 08:55 AM
