Thread: performance shift WTH?
Results 1 to 9 of 9
  1. #1 performance shift WTH?
    May 2008
    McHenry IL
    Ok dont think im dumb i have a 99 GTP as u all no... anyways i no the performance shift on the shifter increases the pressure in some lines... but really is it good to use whenever to gain more power or is it off the line or.... fill me in on my awesome S/C option haha thanks guys!
  2. #2 Re: performance shift WTH?
    Hoffman/Schaumburg, IL
    Performance Shift just raises the shift pressures and shortens the shift times in the trans. It also enables the 3-1 and 4-2 skip-shift downshifts. Sadly there is no increase anywhere else in the system, no additional timing or anything
    But, of racing I would suggest leaving it on the whole time, cause it also rases shift points,letting you get more out of every gear......
    Thats All I got I sure others have more info about it
  3. #3 Re: performance shift WTH?
    Apr 2008
    Chillin at the Beach , VA
    It's basically a push button shift kit. Like blue said, when it's on, it allows your car to shift at a higher rpm than normal.
  4. #4 Re: performance shift WTH?
    May 2008
    McHenry IL
    ahhh ok i gotcha it wont hurt anything if i always just leave it on?? will it hurt the tranny? also will it kill MPG?? thanks alot guys!
  5. #5 Re: performance shift WTH?
    Banned
    Wichita Falls, Texas
    Quote Originally Posted by GTPJOE90 View Post
    Leave it on all the time, isn't going to hurt anything.
  6. #6 Re: performance shift WTH?
    May 2008
    McHenry IL
    gotcha thanks wolf. so it does increase u having a better of the line?
  7. #7 Re: performance shift WTH?
    Barksdale AFB, LA
    No. It only affects shifts and you're not shifting coming off the line.
    2009 Subaru Impreza WRX STI
  8. #8 Re: performance shift WTH?
    Banned
    Quote Originally Posted by Sabrewings View Post
    x2
    Turning off TCS will help you coming off of the line, Perf Shift will help you afterwards.
  9. #9 Re: performance shift WTH?
    May 2008
    McHenry IL
    ok awesome thanks guys
  1. Adding Performance Shift [*]
    By GeddyLee in forum How To Write-Ups/Tech Tips
    Last Post: 08-11-2014, 06:44 PM
  2. performance shift
    By Scott B in forum General Tech Discussion
    Last Post: 06-29-2008, 08:40 PM
  3. ?? about performance shift button
    By DesQ27 in forum Off Topic Discussion
    Last Post: 06-29-2008, 01:13 PM
  4. performance shift light bulb
    By prostreet in forum Off Topic Discussion
    Last Post: 03-12-2008, 09:29 PM
  5. why did they get rid of the performance shift ?
    Last Post: 01-17-2008, 02:18 PM
