Thread: Loud Popping noise from rear end.
Results 1 to 8 of 8
  1. #1 Loud Popping noise from rear end.
    Jun 2011
    Owensboro, Ky
    Just recently, back in February, I had four new struts and rear sway bar bushings put on my 1999 Grand Prix. Now there is a loud popping noise coming from the rear end of the car at low speeds, but rides/handles fine. I had a brake/tire center check all of the rear suspension, and they said everything looked good and tight. What could be causing this?
  2. #2 Re: Loud Popping noise from rear end.
    Likely they looked under the car. Reach in on the top of the strut and see if the top washer is loose under the main nut.
  3. #3 Re: Loud Popping noise from rear end.
    Jun 2011
    Owensboro, Ky
    Through he trunk I'm assuming?
  4. #4 Re: Loud Popping noise from rear end.
    Jun 2011
    Owensboro, Ky
    I checked the top nut. There isn't enough space for my fingers to feel the washer. I bounced the rear of the car. Definitely the right rear.
  5. #5 Re: Loud Popping noise from rear end.
    make sure the main nut and the strut mount are all tight. normally when the bearings in the strut mount start to wear out they clunk around.
  6. #6 Re: Loud Popping noise from rear end.
    Yeah the washer right under that nut spreads the load onto the bearing/mount. If the nut was not as tight as it could be originally , once the mount compresses a little, sometimes there's play. Easy way is to feel the washer.
  7. #7 Re: Loud Popping noise from rear end.
    Sounds like the nut is not tight enough or run down all the way on the threads of the strut..... If the shop checked this while the vehicle was in the air they would assume everything is ok because your suspension hangs freely in the air which puts pressure on the strut,strut mounts and pulls the nut/washer tight against the top of the strut mount.... making it seem everything is tight. Once the car is on the ground your vehicles weight pushes down on the struts making the strut piston (where the nut threads on to) travel back up through the strut mount releasing the pressure of the nut/washer. This is where you get the popping/knocking/clunking sound from every time you hit a bump...
    To correct this you can take the car back to the place where the struts etc were replaced and they'll pull the rear strut assembly out and re-tighten the nut or you can pull the strut assembly yourself and do the same thing (only suggest doing this if you're mechanically inclined) The nuts are usually ran down with an impact wrench though... Then the strut assembly gets reinstalled... and most times you'll need to get the vehicle aligned or at the very least have the alignment checked...
    Snorlax strikes again.
  8. #8 Re: Loud Popping noise from rear end.
    Jun 2011
    Owensboro, Ky
    Thanks guys. I'll have it checked out by the mechanic that replaced them, and I'll let you know what the result was.
  1. Nice popping noise
    By LowRidinCrew in forum General Tech Discussion
    Last Post: 01-28-2011, 05:16 PM
  2. Creaking Popping noise from front end.
    By nawarkk in forum Brakes/Suspension/Chassis
    Last Post: 11-11-2010, 06:21 PM
  3. popping noise.
    By wlmrt6 in forum Brakes/Suspension/Chassis
    Last Post: 10-12-2010, 11:52 PM
  4. Popping noise from the rear
    By tjhgtp86 in forum Brakes/Suspension/Chassis
    Last Post: 03-11-2010, 11:29 PM
  5. Speakers Loud Popping
    By GreenNirvana101 in forum Audio, Security & Visual Electronics
    Last Post: 04-02-2008, 10:32 AM
