Thread: What happened?
Results 1 to 16 of 16
  1. #1 What happened?
    Donating Users
    W-S, NC
    I got on my gtp a while ago and turned the car on and i have no power going to my DIC, Radio or A/C!!! What would cause this? I think it might be a ignition switch harness but not sure. Anyone had this problem before
  2. #2 Re: What happened?
    Apr 2008
    Chillin at the Beach , VA
    Check your fuses yet?
  3. #3 Re: What happened?
    May 2008
    McHenry IL
    yea my home-e badaz is right
  4. #4 Re: What happened?
    Apr 2008
    Don't know if I'm right yet or not. Just wanting to know if all the basics have been checked first. Got to remember to start with the simple stuff and work your way to the hardest.lol!!
  5. #5 Re: What happened?
    Oklahoma
    Moved this to the right section.
    I would first check all the fuses as suggested. It does sound like it could be an ignition switch issue, but check the fuses first. Does the A/C fan work on any speeds at all?
  6. #6 Re: What happened?
    Saraland Alabama
    if you pull the cover off the column there is a black box, squeeze it if everything comes on you need the switch (or epoxy that like I did)
  7. #7 Re: What happened?
    Donating Users
    W-S, NC
    Yes ive checked all underhood fuses and dash fuses... the a/c fan dose not work at all
  8. #8 Re: What happened?
    Apr 2008
    Then that should take you to the next thing, which it gets it's initial power from, like said before, ignition switch. Try what archemedessaid and let us know what you find.
  9. #9 Re: What happened?
    Donating Users
    W-S, NC
    10-4.....will do. See what I can find out tomorrow(if it dosent rain).
  10. #10 Re: What happened?
    SE Level Member Orbital431's Avatar
    Albuquerque, NM
    battery? *shrugs*
  11. #11 Re: What happened?
    TDCRacing
    Guest
    Does the car start?
  12. #12 Re: What happened?
    Donating Users
    W-S, NC
    Yes, car starts and drives as strong as the day I bought it... just no a/c dic or radio
  13. #13 Re: What happened?
    Saraland Alabama
    I lost all of that driving once, and it was from the box in the column
  14. #14 Re: What happened?
    Donating Users
    W-S, NC
    The box on the column was the prob, and yes J.B. weld was my friend lol. Everything's working as it should! Thanks to you all! Big thanks to Archemedes
  15. #15 Re: What happened?
    Apr 2008
    Glad to see you got it all figured out. That's awsome.
  16. #16 Re: What happened?
    Saraland Alabama
    glad it's fixed
  1. Something off happened the other day...
    By Zef_66 in forum General Tech Discussion
    Last Post: 04-23-2008, 08:45 PM
  2. It finally happened - Death of a Tranny
    By SyntheticShield in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-10-2008, 07:11 PM
  3. What happened to the "Forum Jump"
    By Andrew_99GTP in forum Forum Bugs/Suggestions
    Last Post: 01-14-2008, 07:21 PM
