Thread: Which is best?
Results 1 to 12 of 12
fratzke7 Which is best? 07-09-2008, 02:01 PM
archemedes Re: Which is best? 07-09-2008, 10:15 PM
UR LOSN Re: Which is best? 07-09-2008, 10:19 PM
archemedes Re: Which is best? 07-09-2008, 10:20 PM
Sabrewings Re: Which is best? 07-11-2008, 12:16 AM
Zef_66 Re: Which is best? 07-11-2008, 08:04 AM
VinnieGTP Re: Which is best? 07-09-2008, 10:47 PM
Zef_66 Re: Which is best? 07-10-2008, 10:27 AM
VinnieGTP Re: Which is best? 07-10-2008, 04:21 PM
Andrew_99GTP Re: Which is best? 07-10-2008, 05:06 PM
fratzke7 Re: Which is best? 07-10-2008, 09:30 AM
Toofastgs Re: Which is best? 07-10-2008, 11:27 AM
  1. #1 Which is best?
    Donating Users fratzke7's Avatar
    Waterloo, IA
    I am doing some pretty major mods to my car right now and I have noticed that while I have the motor out it would be a good time to replace the coolant....What my question is which coolant will keep my car the coolest? I have a 160* Tstat but would still like to make sure it ran as cool as possible.
    ZZP 3.1 MPS, 2.5" catless exhaust, TOG's, XP hot cam, 105# springs and mod'd retainers, ZZP pcm, alt voltage booster, Wizaired intake, heads lightly ported and 3 angle valve job, PRJ 10.4's, ummm
  2. #2 Re: Which is best?
    Saraland Alabama
    changing coolant won't help it cool better, and keeping the car cold doesn't do anything for performance (just fools the computer into dumping more fuel)
  3. #3 Re: Which is best?
    I live here. UR LOSN's Avatar
    Rockford, IL
    yes get all the dexcool out of there. you can do a search for the Dexcool threads....
    I would change it out to normal green coolant. your radiator will thank you!
  4. #4 Re: Which is best?
    Saraland Alabama
    I prefer the yellow works with anything stuff myself, just in case you don't get it all out, or a shop decides to add some
  5. #5 Re: Which is best?
    Barksdale AFB, LA
    Quote Originally Posted by archemedes View Post
    Prestone's universal (yellow) is great stuff.
    2009 Subaru Impreza WRX STI
  6. #6 Re: Which is best?
    PA
    Quote Originally Posted by Sabrewings View Post
    This is what I use in a 50/50 mix year round in all my vehicles. Never a problem.
    2001 GSE
  7. #7 Re: Which is best?
    GTP Level Member VinnieGTP's Avatar
    Las Cruces, NM
    The way to stay cooler is to a 30/70 water/coolant mix in the summer. Just remember to add more coolant before the first freeze.
  8. #8 Re: Which is best?
    PA
    Quote Originally Posted by VinnieGTP View Post
    FWIW, you would want a 30/70 coolant/water mix. The more water you run, the better in the summer.
    I knew what you mean, I think you just got your mixes all worded up.
    2001 GSE
  9. #9 Re: Which is best?
    Las Cruces, NM
    Quote Originally Posted by Zef_66 View Post
    That's what I meant, it was late.
  10. #10 Re: Which is best?
    GTX Level Member Andrew_99GTP's Avatar
    New Salem, ND
    I am running straight water for now. I haven't taken the time to flush the system and add straight green.
    Red 2dr 99 GTP"Old" Z7 t66, A/A IC'd, Custom Heads, 65# Inj, ST2 Cam, Meziere Elec Pump, JP Double Roller(with machined crank gear), Plogs, PLX W/B, Powrtuner SOLD
    "New" 2007 Duramax ccsb with a few mods
  11. #11 Re: Which is best?
    Waterloo, IA
    I will definitely be changing the dexcool! Just wondered what brand people were using?
  12. #12 Re: Which is best?
    GTX Level Member Toofastgs's Avatar
    Tulsa, Ok
    my car ran 10-15° cooler when i dumped dexcool for slandered green.
    This was messaured by scan master and a tech II.
    Now in my regal i changed dexcool when i did LIM and i dropped a from dead center tick to half way to the next lowest tick with just green coolant.
    00' GTP 350/420 - Retired
    98' GS - Sold
    Current - Lexus ES300
