That is the exact same thing I have.
the add a fuse and go in the fuse slot backwards, just flip it around adn see if it makes a difference.
i say the fuse in the glove box because the radio fuse is the fuse for you interior lights and stuff.
i am thinking its more a relay problem too since you dont here the pump prime. try swaping the fuel pump relay with another one. electrical issues like this suck but its typically something stupid that weve over looked.
After more testing a found that the relays are good but not getting power on pin 87 like the other "working" relays are. What could cause this?
why are you doing the add a fuse?...
it seems to me that thats where your biggest problems are...
mines plugged into #85
I have the add a fuse unplugged and everything else off my battery. Relays and fuses all check out but the ones from above are not getting power like they should from pin 87?
There has got to be a short somewhere. When I got into my car and tried to move electronic seat the car basically died. The battery is showing 12Vs though. I think the next thing I am going to try is to replace the under hood junction box (Fuse box under the hood). At least that will eliminate that as the cause.
It's up and running. Thanks for all the suggestions guys. It ended up being a combination of Relays and bad wiring.
**** wiring.
/end.
Good thing you got it done man...grats!
