Thread: Passenger side cold. Driver hot?!
Results 1 to 4 of 4
  1. #1 Passenger side cold. Driver hot?!
    SE Level Member Wakeboy1337's Avatar
    Dec 2010
    Fort Pierce, Florida, United States
    Now That I finally got all the leas in my system fixed, I vacuumed it down last Sunday and gassed it up. Well I'm glad to say, my car finally has a/c. But only on the passenger vents....
    Let me say that I have a dual climate unit. and it's the manual one.
    I can control how hot or cold each side is just like I would expect. But the driver's side never really gets any lower than a TINY bit colder than the outside air temp. I've got a couple of places to go, then I''l take the dash cover off and see if any hoses popped off. But I'm posting this now in case anyone has specific recommendations for me.
  2. #2 Re: Passenger side cold. Driver hot?!
    double check the levels with a full gauge set, keeping in mind the relative temp/humidity. I've seen this be an actuator, but commonly it's an improper charge level.
  3. #3 Re: Passenger side cold. Driver hot?!
    Denver
    You are most likely low on refrigerant.
    The evaporator is nearer the passenger side so when it's halfway working, you will get cold air from the pass side and warmer air from the driver side.
    I had the EXACT same problem not too long ago. After tearing apart my servos and dash, I confirmed there was nothing wrong with the mixing (to operate dual climate). I added more refrigerant (I was doing a recharge anyway) and the problem is now gone.
    I did this over a process of about ~3 charges over 15 minutes. It went from cold pass/warm driver to cold pass/cool driver to cold pass/driver all with the addition of more R134a.
    For me, the mixing operation (dual climate) was a total red herring - the problem was entirely low R134a.
  4. #4 Re: Passenger side cold. Driver hot?!
    Dec 2010
    If that's the case im gonna check it with a gauge everyday for a few days before I add a charge. r134 is too expensive to keep wasting.
  1. A/C cold on passenger side and luke warm on drivers side
    By IFrees in forum General Tech Discussion
    Last Post: 05-14-2011, 05:06 PM
  2. not the passenger but the driver...
    By GAFF in forum Off Topic Discussion
    Last Post: 09-07-2010, 01:56 PM
  3. Driver side wiper arm slips down to the side mirror
    By kappian in forum General Tech Discussion
    Last Post: 04-05-2010, 08:43 PM
  4. Driver door up, driver side unlock and power mirrors are out!!! Help
    By Dangerous313KidInAPrix in forum Audio, Security & Visual Electronics
    Last Post: 11-25-2009, 12:12 PM
  5. Side mirror on driver's side
    By jokyfo in forum Shops and Community Heroes
    Last Post: 04-29-2009, 03:50 PM
