Thread: Driver side door window doesnt always go up
Results 1 to 10 of 10
  1. #1 Driver side door window doesnt always go up
    GT Level Member tcman49's Avatar
    Apr 2011
    Palm Coast, Florida
    2001 GTP Coupe
    My driver side door window only goes up about every 6th time I press the door switch, it always sends the window down but only up about every 6th time like stated above.
    If I got a new door switch would that fix the problem and is it something that I could install?
    thanks
    TC
  2. #2 Re: Driver side door window doesnt always go up
    Fort Wayne, IN
    It sounds like the all too reliable GM window regulators. Mine was going down fine but going up really slow and when cold it wouldn't go up at all. Replaced the regulator and motor and it was fine.
  3. #3 Re: Driver side door window doesnt always go up
    Waukesha, WI
    regulator for sure, haha gm quality
    RayRay
    92 Turbo miata
    71 bagged lemans wagon
    02 lexus is300
  4. #4 Re: Driver side door window doesnt always go up
    Houston
    Mine did that once...I had to jump 12v to the window motor to get it to roll up. It went down just fine. I replaced the switch and that was the end of that noise.
  5. #5 Re: Driver side door window doesnt always go up
    St. Louis
    Also grease the guides as they tend to dry out and grab the glass on the way up. You may want to pull the door panel to get the lower portion. Even with new regulators/motors my drivers side was slow to go up until I did this. Also spray the felt guides around the window frame with some type of lube. I found one that dries w/o leaving streaks and it made a world of difference.
  6. #6 Re: Driver side door window doesnt always go up
    Apr 2011
    Palm Coast, Florida
    Quote Originally Posted by FordMan77 View Post
    what kind of grease or lube?
    thanks
  7. #7 Re: Driver side door window doesnt always go up
    St. Louis
    This is what I've been using for the felt guides around the window frame. For the metal guides in the door I just use a good bearing grease.
  8. #8 Re: Driver side door window doesnt always go up
    Minnesota
    I know im bringing this one back from the dead. But what wires do you jump with a 12v? My window is all the way down and wont go back up. It started off about 2 inches down and had no problem going down each time I pressed it, to try and get it to go back up. I tried to push it up with my hands with the door panel off but couldnt do it. What is a quick fix just to get the window up for now until I can replace the regulator?
    Open cone, SSAC headers, cat delete, 8.5 MSD wires, 3.4 zzp mps, 180*, 104's, ported blower, DHP canned tune, 19" XXR 962s, DNA springs.
  9. #9 Re: Driver side door window doesnt always go up
    St. Louis
    Not sure on which wires to jump, but you could just unbolt the window from the regulator (2 bolts) and jam something underneath the window to keep it up. I used some styrofoam I had laying around. Could use a piece of wood as well.
  10. #10 Re: Driver side door window doesnt always go up
    Donating Users Burgundyman's Avatar
    use duct tape to keep it. Just remember to remove glue residue.
    1998 Grand Prix - GTP
    RED- 4 Door Sedan
  1. Driver side window
    By Wings672 in forum How To Write-Ups/Tech Tips
    Last Post: 05-26-2010, 04:42 PM
  2. Can't put driver's side window up!
    By Deezul_AwT in forum General Tech Discussion
    Last Post: 04-12-2010, 12:50 PM
  3. Driver door up, driver side unlock and power mirrors are out!!! Help
    By Dangerous313KidInAPrix in forum Audio, Security & Visual Electronics
    Last Post: 11-25-2009, 12:12 PM
  4. Window Problem (Front Driver Side Window)
    By trogdor007 in forum General Tech Discussion
    Last Post: 06-03-2009, 09:22 PM
