Have you checked the oil to make sure it's actually full?
If it's full and you're still getting the light then the oil level sensor is located on the front of the pan. It's the big nut thing that is screwed into the edge of the pan. Can't miss it. Also check the wiring going to it to be sure it's not screwed up and causing a false light.
