Thread: I need some help with my 1999 Grand Prix GTP!
Results 1 to 10 of 10
  1. #1 I need some help with my 1999 Grand Prix GTP!
    May 2011
    Massachusetts
    About a month ago I was driving and the idler puller fell off, which caused the belt to fall off. I then replaced the idler pulley and reattached the belt. A week later the service engine light came on and was giving a PO101 code (faulty MAF) and a PO171 (bank 1 - system too lean) and the car was idling very high, had lack of power, and would stall every now and then. I found out the MAF did need to be replaced and some of the vacuum lines as well. I thought by fixing those things the car would be fine, but now when the car is idling or I'm stopped, the RPMs will move up and down by themselves and sometimes it stalls. There is currently no error codes and the car does seem to run better when it's not too warm out. I'm hoping someone may have some advice because I have absolutely no idea what could be wrong!
  2. #2 Re: I need some help with my 1999 Grand Prix GTP!
    hmm. Kinda sounds like one of the other sensor on the throttle body may be having a issue.
    Those would be the IAC (idle air control valve) and TPS (throttle position sensor).
    You can take the IAC out and try cleaning it, or see how bad its gummed up with crap.
  3. #3 Re: I need some help with my 1999 Grand Prix GTP!
    Omaha, NE
    Sounds like it could be a bad gasket if the maf and all vac lines are good.
  4. #4 Re: I need some help with my 1999 Grand Prix GTP!
    Also does the car stall at idle or while driving. Like have you come up to an intersection and BAM, out of nowhere the car just dies??
  5. #5 Re: I need some help with my 1999 Grand Prix GTP!
    GT Level Member Tea Time's Avatar
    New Brunswick
    check all the vac lines ...spray with brake clean and if the idle rises then u found the area of ur leak, my gtp displayed the same symptoms when the T fitting on the lim went bad (it dry rotted).
    '00 GTP - Summer Toy
    '97 GTP - Project
    '99 GT - Gone (Frame Rotted)
    '98 SE - Gone (Parts Car)
  6. #6 Re: I need some help with my 1999 Grand Prix GTP!
    May 2011
    Massachusetts
    I can tell when it's about to stall. For example, if I sit at a red light for too long the RPM's will go up, the car will jerk forward a bit, and then just die.
  7. #7 Re: I need some help with my 1999 Grand Prix GTP!
    MA
    hey melissa, welcome to the forums!
    if i may, just slide this here for you to check out New England Pontiac Enthusiast Club :: Index
    theres alot of knowlegable guys in our area, who love to help
    SMGPFC Member #9
  8. #8 Re: I need some help with my 1999 Grand Prix GTP!
    Donating Users
    South Deerfield, MA
    ^^ What area of MA are you located in? Like Silva said, there are a few of us around the state that could help you look at it.
    2002 GTP: GMPP Sway Bars, BMR trailing arms, KYB AGX/Vogtlands, 12" brake upgrade
    Modified SSAC headers, K&N Intake, 3.4 MPS, S1X, Gen V, 104's, HPTuned.
  9. #9 Re: I need some help with my 1999 Grand Prix GTP!
    May 2011
    Massachusetts
    I'm about 20 minutes north of Boston.
  10. #10 Re: I need some help with my 1999 Grand Prix GTP!
    GT Level Member Dtrick22's Avatar
    Jul 2010
    Holyoke, MA
    Quite a few guys out that way......And SilverGTP, LOVE those rims
    2006 GT- S1x, 3.25 MPS, Lucas 42.5, MAF, SD Headers, C5 Brakes, AGX/Vogtland, GMPP sways
    Quote Originally Posted by Wotgtp View Post
    I eat, drink, sleep, and masterbate to grand prix's. Come at me bro.
  1. Danielle's 99 GT :)
    By danielle15 in forum Members Rides
    Last Post: 04-08-2013, 01:52 PM
  2. 1999 Grand Prix Rebuild
    By mostfunwithfire in forum Off Topic Discussion
    Last Post: 03-21-2010, 11:03 PM
  3. 1999 Grand Prix no go
    By Kreitoc in forum General Tech Discussion
    Last Post: 09-27-2009, 03:37 PM
