Taking a look at it. You'll see that two should have a white clip inside them. Push the line toward the pump and squeeze the white clip then pull the line off. Should come easily. The other is an oval and simply needs to be squeezed into a circle and it'll pull off.
The only tough part with these clips is the limited room. Once you get past the room issue..they are easy.
