Thread: AC condenser testing?
Results 1 to 8 of 8
  1. #1 AC condenser testing?
    SE Level Member codysGS's Avatar
    Port Perry Ontario
    Hey, summers coming up, I'm looking to get my AC re charged, last year I went to do this, he said its likely the condenser has a tonnes of bent fins. My mechanic said its likely that but he was unsure, it could also be the ac coil in the dash, or how ever the cool air exchanges into the system,
    My question, is there a way to test ur condenser? Other then the ac leak test? Or am I best replacing the condenser with a used one $50 and then trying it again?
    My rides: 1986 Pontiac Fiero GT fastback 300 SeriesII NA manual
    1999 Buick Regal GS, fenderwell intake, 5 percent tint all round SOLD
    1986 Pontiac Fiero SE 2M6 blown up 3.8na GONE 1989 GMC S15- Derby truck
  2. #2 Re: AC condenser testing?
    If you told us what the issue was, we could probably help you better.
    A cheap fine tooth comb, stool and an hour can fix a lot of bent fins on a condensor. Typically a condensor doesn't go bad, it'll have bent fins or leak. That's the most that typically occurs.
    A clogged orifice tube can cause poor performance.
    The evaporator core (in dash) usually doesn't cause any issues either)
  3. #3 Re: AC condenser testing?
    Port Perry Ontario
    sorry, i have absolutly no ac, we did a leak down test and it showed a slow leak, but we couldnt hear where it was coming from, this was last year, i have some money now and was thinking if getting it fixed. My condenser has one corner that is crushed, all fins are flat..... im thinking theres my leak? but other then replacing it and trying a leak down test again i cant think of another way? all in all im trying to find a leak, replace leaky part and then get it recharged, a local wrecker has better looking condensers for $50
  4. #4 Re: AC condenser testing?
    Charles City, IA
    charge the system and put dye in it to find the leak.
    SMGPFC Two Nipple General
  5. #5 Re: AC condenser testing?
    Waukesha, WI
    check all connections, mostlikely ac compressor.
    bill doesnt wbodys use a reciever dryer system? no orifice tube
    RayRay
    92 Turbo miata
    71 bagged lemans wagon
    02 lexus is300
  6. #6 Re: AC condenser testing?
    Donating Users DOHCZ34's Avatar
    Traveling
    Do an evac and recharge with some dye in it, then check over everything with a black light to find the leak, just hope it's the condensor. That's probably the cheapest component you could replace besides the dryer, which rarely are bad.
    Traveling Tuning Authority
  7. #7 Re: AC condenser testing?
    Port Perry Ontario
    fingers crossed for compresser thanks guys
  8. #8 Re: AC condenser testing?
    Waukesha, WI
    theyre easy to replace if that is what it is
    RayRay
    92 Turbo miata
    02 lexus is300
  1. 05 GTP Condenser
    By dsteinmann in forum General Tech Discussion
    Last Post: 05-16-2011, 05:46 PM
  2. air conditioning condenser
    By Hosscat101 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-29-2010, 06:58 AM
