how do you remove the power mirror switch on 05 Pontiac grand prix I tried to pry the whole panel out that has all the goodies on it no luck is there a special trick?
The door panel has to come off. Here's instructions from the service manual on GPONA.
Remove the push button from the front door lock.
Insert a flat-bladed tool at the front edge of the door handle bezel. Pull the bezel away from the door to disengage the retaining clips.
Remove the pull handle cover.
Notice: Use a thin walled socket or a Torx® head driver to remove the pull handle screws. Do NOT use a standard socket, which will split the plastic tubes that locate the screws.
Using a thin walled socket or Torx® head driver, remove the screws (1) from the pull handle.
Use J 38778 to disengage the push-in retainers and remove the trim panel from the front door inner panel. Begin at the lower rear of the panel.
Lift the panel up to disengage the channel at the top door edge and at the door lock push button.
Disconnect the electrical connector to the door electric harness. Use a flat-bladed tool to disengage the gray cam lock. Lift the cam lock and separate the connector.
Remove the front door trim panel from the vehicle.
