Just got a set of gauges hooked up and wanted to run these numbers past someone to see if they look about right.
Cold Idle Park or in gear- 70
Cold Cruising- 75 @ 35mph 75 @ 60mph
Cold WOT- 88 (may be low due to the fact that its raining out and I started to spin the tires and backed out of the throttle)
Hot idle or in gear- 49
Hot Cruising- 62 @ 35 mph and 60mph
Hot WOT (again, weather limited)- 75
Also, showing 14 volts and a trans temp of 152* with outside temp being 50* after 1 hour of highway driving. With the sensor not in the pan of the trans and only in the pressure port not sure how accurate this is. I plan on welding a bung into the trans pan next time I drop it for service.
Do these readings seem about on par for a 00GT that has around 119K on the motor/trans? Oh, and props to Machinegunsquid for the sweet Autometer gauges/pod. They look/work great!
