thats a lot of oil pressure.
with 0W-20 i'm seeing 65 on startup,
60 crusing hot.
65-70 WOT.
30 hot idle in gear.
Trans temp is difficult, the best reading is what the PCM claims.
60 crusing hot.
65-70 WOT.
Yeah, w/o and Aeroforce the trans temp is an estimate. I think I'll have to take some new readings as it appears my oil gauge had a loose connection and may have been reading wrong, but I know it's not too far off.
As long as the oil pressure isn't over 100 then I'm good. Otherwise I'd have to tear the pressure regulator apart and fix it. I'm using the stock recommended weight for oil. Just good ol dino oil, nothing fancy.
Your readings are about what I'm used to seeing. I have a manual oil pressure gauge (mechanic grade) that I use for trans pressure and oil pressure when testing.
As for the trans temp. That would be in a good trans w/o much slippage. It's right in the area what I would see when my trans was happy.
