yes low fluid would make the pump whine.
does the power steering work now?
Its not just a whine, its a rumble lol. O'reillys closes at 10 so im just waiting for a ride for more fluid. I sure hope it fixes the problem though.
Alright, Got some more power steering fluid filled it up. Bleed it. Ran the car and turned left to right. The noise did get a little more quiet. Bleed it again. Tightened up the bolts on the pump a little more. Its quiet but I can still hear the noise. It sounds like a bad bearing grinding.
Took it for a test run, the steering is a little better. I thought there would have been a bigger difference.
I can hear the pump wine as I give it gas, its quiet but I can hear it and feel a vibration in the steering wheel. And when I do turn all the way to the left or right, you can definately hear the pump and feel it.
Did I get a bad pump? Did I install it wrong?
This always happens to me. Grr.
But its the pump making the noise, My old pump was doing better than this new one.
How difficult is it to replace rack and pinion?
i haven't done one yet or mine, im following this write up http://www.grandprixforums.net/04_rack_replacement.php it don't look to bad, bill boost recommended lowing the back of the cradle as well.
Hmm, not sure If I am up to doing that. I'm still not really convinced that is the problem. I guess I will tinker aroud a little and try to solve this small annoying problem.
