Thread: A/C cold on passenger side and luke warm on drivers side
Results 1 to 7 of 7
  1. #1 A/C cold on passenger side and luke warm on drivers side
    SE Level Member IFrees's Avatar
    Illinois
    Anyone have an idea what causes the A/C to be ice cold on passenger side and luke warm on drivers side?? I have dual climate controls set to the cold position with a/c on..... i'm stumped.
  2. #2 Re: A/C cold on passenger side and luke warm on drivers side
    SE Level Member hockey101's Avatar
    Detroit, Michigan
    I have the same problem in my 97 gt. Although i don't have dual climate.
    I've talked with a few people and it sounds like it may be the HVAC.
  3. #3 Re: A/C cold on passenger side and luke warm on drivers side
    sometimes its because your a/c is low on freon or "R" whatever these days, and that causes it, or it could be the blend door actuator. do a search on your title and theres a bunch of threads already with part # and photos.
  4. #4 Re: A/C cold on passenger side and luke warm on drivers side
    Troy OH
    HVAC stands for "heating, vacuum, air conditioning"
    if the evaporator is on the passenger side on these cars, it's very possible you're low on refrigerant (R-134a). also as scotty said, could be a blend door actuator. seeing as how your car is roughly 10 years old and probably hasn't had any sort of maintenance on the a/c system, you're low. take it to a shop, they'll charge it, fill it with dye, and you can go back if it stops working and they'll find your leak.
    if it's a blend door, you're looking at taking your dash apart. sounds like a great afternoon. mine's getting stuck on heat and blowing hot air on my feet all the time. i need to fix it before my foot fights back
  5. #5 Re: A/C cold on passenger side and luke warm on drivers side
    Illinois
    These are the two things I'm debating on. Taking it to the shop next week sometime I will post what I find out. They most likely said it was a blend door actuator which is controlled by a vacuum said the hose could have fallen of or have a crack.
  6. #6 Re: A/C cold on passenger side and luke warm on drivers side
    Illinois
    Oh and about the recharge it was fully recharged back in november and worked fine until about a month ago
  7. #7 Re: A/C cold on passenger side and luke warm on drivers side
    Troy OH
    most likely the blend door actuator then
  1. Heater blowing cold on drivers side
    By sophie in forum Introductions/Noob Questions
    Last Post: 11-03-2010, 08:00 PM
  2. drivers side CV shaft
    By Jakegday in forum General Tech Discussion
    Last Post: 07-03-2010, 05:42 PM
  3. drivers side axle
    By planogtp in forum General Tech Discussion
    Last Post: 12-22-2009, 07:50 PM
  4. GTP drivers side axle?!?!! HELP!
    Last Post: 12-20-2009, 11:52 PM
  5. front drivers side sits higher than passengers side
    By tjvdubsport in forum Brakes/Suspension/Chassis
    Last Post: 06-12-2009, 06:21 PM
