Thread: Replaced Power Steering pump, now making noise.
Results 1 to 9 of 9
Threaded View
  1. #1 Replaced Power Steering pump, now making noise.
    GT Level Member fri3dchick3n's Avatar
    Alaska
    Today I decided it would be a good day to do the Power Steering pump for some reason. The first time taking everything off then back together took me a while. I followed each step perfectly, When I first started the car to check how everything is, a bunch a fluid was just spilling out from the resovior-pump connection. I knew excactly what was wrong. The pump had no O-ring -.-.
    Took it all apart instantly, took about 10 minutes. Installed the O ring from my old pump put everything back together with a breeze. Got the technique down from the first time, such a pita.
    Started the car, no leaks but this awfull grinding sound is coming from the pump. I re-bleed the system again and the same noise is happening. I checked my fluid and it low. (Lost a most of my fluid from the first experience).
    Could low fluid be causing this noise.
    http://s1183.photobucket.com/albums/...t=IMG_0554.mp4
    Friday 13th?
    99 GTP: 3.4'' MPS, Overkill PCM, Intake, Catless SD Headers, TransGo Shift Kit, 180º Thermostat, Flipped Dog Bones
  1. 99 GT power steering pump
    By BmoreDrew in forum General Tech Discussion
    Last Post: 04-10-2011, 11:13 PM
  2. power steering pump
    By indyal in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-18-2009, 04:26 PM
  3. Power steering pump noise
    By minichopper6hp in forum General Tech Discussion
    Last Post: 07-18-2009, 01:57 AM
  4. replaced power steering pump and now it is squeeling and leaking badly! Help
    By Cheri in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-07-2009, 08:10 AM
  5. Power Steering pump
    By airhead in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-15-2008, 07:16 AM
