Thread: Rpms on the highway?????
Results 1 to 10 of 10
  1. #1 Rpms on the highway?????
    SE Level Member nickdemio's Avatar
    STL
    When im on the highway my rpms will go up & down between 1000 and 2000 even if my foot stays on the gas...does anybody know what could cause this?? It just started today while driving to work and has never happened before.
    2001 GP GT
  2. #2 Re: Rpms on the highway?????
    St. Louis
    So the tach is bouncing, but how does the car run? Any different or it runs fine while its doing this?
  3. #3 Re: Rpms on the highway?????
    STL
    Well, i only feel the difference when it jumps up...the car kinda accelerates & then when the tach jumps down the speed just evens out to the amount of pressure im putting on the gas pedal..guess u can say it evens out. Not a big difference tho...car dosent chug or anything.
    2001 GP GT
  4. #4 Re: Rpms on the highway?????
    are the rps, actually going up and down or is it just the tach, or is it more like you are slipping out of overdrive and into 3 rd gear?
  5. #5 Re: Rpms on the highway?????
    STL
    Jus the tach i guess..cuz i dont feel a big difference in the way the engine is performing..cuz it should with the rpms jumping between 1000 to 2500!
    2001 GP GT
  6. #6 Re: Rpms on the highway?????
    St. Louis
    I wonder if the CPS is starting to go? Usually the tach just bottoms out before the engine shuts down, but I guess an intermittent signal would do this.
  7. #7 Re: Rpms on the highway?????
    SLP, GTP or call it MUT! thunder71173's Avatar
    West Frankfort Illinois
    It is the common fluctuating rpm condition that is caused by one of the sulenoids on the tranny. Mine has had the problem since I purchased it. Check tep's site
  8. #8 Re: Rpms on the highway?????
    STL
    Is that something i need to worry about & get fixed? Is it a easy fix..like how much would it cost to fix? and wouldnt it throw a code?
    2001 GP GT
  9. #9 Re: Rpms on the highway?????
    Never Never Land
    mine does it...never throws a code. However you should be able to feel it jerking. If you can't and it's fluctuating a whole 1500 rpms then I think it would point more toward a CPS. Does your tach ever just die?
  10. #10 Re: Rpms on the highway?????
    STL
    Tach never dies & today was the 1st and only time it has done this.
    2001 GP GT
  1. highway over heating
    By gtpsleeper in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-07-2010, 04:32 PM
  2. highway driving
    By GTP Ryan in forum Off Topic Discussion
    Last Post: 07-14-2010, 10:35 PM
  3. retards on the highway
    By Poil336 in forum The Rant Forum
    Last Post: 12-06-2009, 12:17 AM
  4. Highway Issues
    By MuTaLiZeD in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-24-2009, 09:36 AM
  5. Highway Cruising
    By JDCMoney in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-20-2009, 03:31 PM
