Thread: ses light on
Results 1 to 8 of 8
  1. #1 ses light on
    SE Level Member tstaller2005's Avatar
    minneapolis
    Hey guys so yesterday coming back from Tennessee My SES light came on because the RPMs kept dropping. I took it in today to see what was causing the problem and some of you thought the crankshaft position sensor, which could still be a problem but not the one they found. It was code P0102 which has to do with air flow. They say possibly the MAP sensor, a dirty sensor, possible vacuum hose cracked off or leaking, or the throttle body intake tube loose, cracked or off. How hard is it to check or fix any of this if its one of those?
  2. #2 Re: ses light on
    minneapolis
    plus does anyone happen to have one laying around that works and they dont need it?
  3. #3 Re: ses light on
    Wichita
    I beleive that's a bad Mass Air Flow code. First thing you should do is follow all your vacuum lines checking for loose lines or cracks. Then, If you don't find any problems there see if you can clean your MAF sensor. If that dosen't work maybe you need a new MAF.
  4. #4 Re: ses light on
    minneapolis
    yeah I am having my vac lines replaced and my MAF sensor as well. I hope it fixes my issue.
  5. #5 Re: ses light on
    Quote Originally Posted by tstaller2005 View Post
    junk yards sell used maf sensors for about 40 bucks, and there always ebay, look at the top of the maf, and copy down the part # then search for it.
  6. #6 Re: ses light on
    I break stuff selliott's Avatar
    Kansas City
    I would guess its a vacuum line like everyone else is saying
  7. #7 Re: ses light on
    minneapolis
    yeah I am going to have my vac lines changed out. hope thats all it is. I am trying to get my hands on a cheap or free MAF in the mnclubgp forums but everyone that has one is for a 2000 or newer and I cant use those. This stinks
  8. #8 Re: ses light on
    Wichita
    Try an ebay MAF. I got one off there & it still* works. they are reasonably priced. Won't cost you the full $276 some odd dollars it normally would.
    *=Dunno when/if it's gonna fail on me though.
  1. Replies: 5
    Last Post: 10-04-2012, 02:40 PM
  2. Service Vehicle light, ABS light and intermittent stalling
    By regalls in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-29-2010, 10:33 AM
  3. Water in LR brake light housing/ABS light
    By andante147 in forum General Tech Discussion
    Last Post: 05-31-2010, 08:01 PM
  4. Replies: 16
    Last Post: 01-23-2010, 09:43 AM
  5. ABS Light + Check Tire Press. Light Problems
    By element55 in forum Brakes/Suspension/Chassis
    Last Post: 01-30-2009, 02:34 PM
