Thread: L67 rebuild considerations
Results 1 to 12 of 12
  1. #1 L67 rebuild considerations
    Feb 2010
    South Dakota
    Hello all,
    I have a 98 gtp with over 200k on it, the whole care is in very bad shape but it has a decent running motor and a operational tranny. Not bad for the $100 investment. What i want to do with it is a complete engine teardown and rebuild so that i can have some solid ponies to put into my 2002 GT. Im not sure what i will have to do with the transmission i would like to keep the 02 tranny if possible but i do not know if the electrical will jive. At this point im just getting ready to pull the motor out of the donor car. I plan on sticking 5-7k into this motor after the rebuild and prolly a pcm tune. I want a better than new motor and plan on doing as much of the work on my own as possible. So far i think im going to make a valley pan, replace the oil pump, balance/polish the rods and crank prolly look into getting new rockers and at least grind the valves. Im not sure which rebuild "kit" i want to buy but everything mechanical needs to be in the like new or new condition. Other than that im not really sure where i want to go with this. I plan on making this one of those longer term learning projects. i have done hours of reading on this motor and i know there are many many possibilities for this motor, hoping some of you guys can get me pointed in the right direction.
    Thanks in advance,
  2. #2 Re: L67 rebuild considerations
    you're wasting your time. if the motor runs fine you're just wasting money.
  3. #3 Re: L67 rebuild considerations
    Hagerstown,Md
    there was a GP with 230K miles that ran 11's on its stock bottom end
  4. #4 Re: L67 rebuild considerations
    Waukesha, WI
    there 600+ whp car on stock bottemends
    RayRay
    92 Turbo miata
    71 bagged lemans wagon
    02 lexus is300
  5. #5 Re: L67 rebuild considerations
    Feb 2010
    South Dakota
    The l67 runs decent, as in i would not be afraid to drive it to work. It does not run good, but it runs. I also know this car had the living **** rodded out of it and it was ran OUT of oil at least once by the previous owner. I want a motor with plenty of power that i can trust driving across the country, not the county. As far as im concerned it will get a fresh breath of life even if its just the plain jane standard rebuild. But since im already going to spend the time i want it to be bigger, better, and faster.
  6. #6 Re: L67 rebuild considerations
  7. #7 Re: L67 rebuild considerations
    Troy OH
    if you find a place that sells factory replacement connecting rod bolts, let me know. if you're just rebuilding it, you probably won't touch 5k. if i could find new bolts, i could get gaskets and rebuild a stock motor for roughly 1500. if you have 5k to spend, just drop it off at a machine shop and tell them to make it new again. everything comes back clean, balanced, and practically new. have your heads ported, run a bigger cam/stronger springs/double roller timing set and an intercooler. or don't intercool, and spend what you have left on a new transmission. and then you're close to 7k... maybe. and you're running 11's
  8. #8 Re: L67 rebuild considerations
    Feb 2010
    South Dakota
    I don`t know what you mean by:"and you're running 11's".
  9. #9 Re: L67 rebuild considerations
    Quote Originally Posted by 02Prix View Post
    A fair number of us try to make are cars quick in the quarter mile.
    If you want to rebuild, it will cost you at least a grand.
    Or more.
    And while its apart you might as well upgrade things.
    Then your stock transmission won't be happy.
    I'd just swap the motor in and enjoy it while it lasts.
  10. #10 Re: L67 rebuild considerations
    I break stuff selliott's Avatar
    Kansas City
    Turbo!
  11. #11 Re: L67 rebuild considerations
    Kansas City
    ^^ agree ....once you start upgrading it becomes a where do I stop thing.
  12. #12 Re: L67 rebuild considerations
    Quote Originally Posted by selliott View Post
    C'mon...how can you say stuff like that? I nearly ran out of mods to buy when I was in the game. Literally the motor had nearly 1 of everything.
  1. Rebuild it?
    By Marks97GTP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-17-2010, 07:22 AM
  2. rebuild $$
    By go8earn in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-07-2010, 09:02 PM
  3. rebuild $$
    Last Post: 02-07-2010, 08:59 PM
  4. to rebuild or not to rebuild
    By indyal in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-30-2009, 04:14 PM
  5. Considerations for building a Track use GTP?
    By Quicklynx in forum Brakes/Suspension/Chassis
    Last Post: 09-03-2008, 03:30 PM
