Hopefully within the next month I will install the wideband. I may have to try it's narrowband output so I can use the sensor location of the new bung. I also moved the 3" v-band to above the flex, so that if/ when it fails only the downpipe will need to be removed for repair. I think this also made it easier to install from above as I believe the flex would have been in the way.
