alright so heres a few key things to keep in mind
-make sure your hood is open before you jack the engine up....
-if you have a stb it needs to come off...
-use a 2x8 12 inchs long or something the same size or bigger or you will dent your oil pan I used a 2x6 about 8 inches long and it pretty much raped my pan aparently their weak as ****
-I used a giant ass ratchet thing idk what its called but [its got two hooks braided cable and a arm about two feet long] to get the holes to line up took about 10 seconds I stuck one hook in a hole of the body on the underside and the other on the bracket
I learned all of the above tha hard way... so you don't have to : P
