Thread: Opinions on CV Joint Repair or new half shafts
Results 1 to 5 of 5
  1. #1 Opinions on CV Joint Repair or new half shafts
    Quakertown, PA
    If this is not the right forum for this question, please move to proper one.
    Yesterday, while replacing my front brake rotors and pads, I noticed that the driver's side half shaft boot closest to the tranny was slinging out green grease onto my lower frame. Not a lot, but enough to scrape off. I looked it over as best as I could but couldn't really see a split or hole. My question is: should I go to the trouble of pulling the axle, and replace the joint boot? Or, should I just buy a new/remanuf. half shaft and put that in?
    If another half shaft, whose do you recommend? I see that AZ has them, as does NAPA (both new and remanuf). Or, should I get a used one from Ed Morad? So far, I do not have any noises or indications of CV joint failure but I want to take care of this before that happens.
    Thanks for any advice you can give me.
    '02 - 3.8(K) 153,000 miles, New UIM, New LIM alum. gasket, new lifters, new OEM cat. Runs great ! Owned it since new. (bought it 12 years ago with only 22 miles on the clock)
  2. #2 Re: Opinions on CV Joint Repair or new half shafts
    had the same thing happen to me,
    just buy a remaned one you get new bearings and joints full a grease so it just better and there about the same price anywhere you go and plus theres a core charge to to you can get alittle back, but i got mine from orileys and they price match so its a win win
    SMGPFC Member #10
  3. #3 Re: Opinions on CV Joint Repair or new half shafts
    SE Level Member GTPWombat's Avatar
    Apr 2011
    Mountain Home, Idaho
    I would replace the half shaft. Not only do you get a core but a warranty as well.
  4. #4 Re: Opinions on CV Joint Repair or new half shafts
    Banned
    Apr 2011
    wv
    the new halfshaft is usually $20 more at most, and there is no core to hassle with.
  5. #5 Re: Opinions on CV Joint Repair or new half shafts
    GT Level Member firstdue's Avatar
    Toledo, Ohio
    My right front is slinging grease. Any recomendations on what brand may be better? Thanks!
    2009.1 Liquid Red G8 GT
    2001 Grand Prix GT Bright Red
  1. cv joint question
    By SilvrGrandPrixGT in forum General Tech Discussion
    Last Post: 05-01-2011, 03:05 PM
  2. New Half Shafts on lowered 98 GTP
    By hunttom in forum Brakes/Suspension/Chassis
    Last Post: 03-12-2011, 09:08 PM
  3. half shafts bad?
    By DEZI425 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-02-2010, 10:49 AM
  4. Ball joint?
    By kissmyss in forum Brakes/Suspension/Chassis
    Last Post: 06-07-2009, 04:59 PM
  5. Steering / CV Joint?
    By Egleone6 in forum General Tech Discussion
    Last Post: 04-08-2009, 11:08 PM
