Thread: oil pressure gauge
Results 1 to 7 of 7
  1. #1 oil pressure gauge
    Joliet, IL
    will i need any adapter if i remove the stock one? i dont need a sensor that alerts me below 5psi as i will see that on the gauge anyway......will i need an adapter for the new sender? im using a aem digital oil pressure gauge.....
    00 Silvermist GTP
    13.2 @ 104. No Cam No IC.
  2. #2 Re: oil pressure gauge
    nope, if should come with its own little sender thingy, it screws in the same spot as the factory one, use some teflon tape so it dont leak.
  3. #3 Re: oil pressure gauge
    Banned
    Apr 2011
    wv
    how are you mounting it?
  4. #4 Re: oil pressure gauge
    Houston
    My sending unit needed a 1/8" to 1/4" thread adapter. I found mine at O'reillys. Autozone told me I would have a really hard time finding one. So I walked next door to O'reillys and they said, "Yeah, we have one"
  5. #5 Re: oil pressure gauge
    Banned
    Apr 2011
    wv
    haha autozone fails
  6. #6 Re: oil pressure gauge
    Houston
    They fail me almost every time. But I keep going back....so Im the idiot, not them.
  7. #7 Re: oil pressure gauge
    Commerce Twp., MI
    I went to home depot and got a 1/4 brass T, and the adapter like above. Used Teflon tape on all the connectors and put the T in the block with both sending units on it, so that the little oil light would not stay on in the gauge cluster.
    I put the side of the T in the engine, with the new sending unit straight out and the OEM unit on the top.
  1. Volt and oil pressure gauge help
    By DBGP in forum General Tech Discussion
    Last Post: 01-10-2011, 08:38 AM
  2. Oil Pressure Gauge...
    By mickey t in forum General Tech Discussion
    Last Post: 08-31-2009, 10:56 PM
  3. fuel pressure gauge
    By gtchris in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-13-2009, 02:43 PM
  4. Boost and oil pressure Gauge
    By jacobmh27 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-24-2008, 06:40 AM
  5. how to use a fuel pressure gauge?
    By Toasty in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-10-2008, 01:06 PM
