Thread: Drivetrain work (trans swap 5 hours)
Results 1 to 13 of 13
  1. #1 Drivetrain work (trans swap 5 hours)
    Matt... this ones for you.
    I hit the chat box at 9:52 when the car arrived. Got into it and at 12:03 I stopped. Went from driving the car in to this in 2 hours.
    Already sent a text message about replacing the mount
  2. #2 Re: Trans swapping (out in 2 hours)
    Charles City, IA
    good work, the one I did took me like 4 hours to pull.
    SMGPFC Two Nipple General
  3. #3 Re: Trans swapping (out in 2 hours)
    GTX Level Member cliffdawg's Avatar
    Midvale, Utah, United States
    wow just dropped the sub frame i had my engine pulled in a hour and half so i can replace the flex plate or i would of gone that way
    SMGPFC #77
    94 Firehawk - #108 of 500
    97 GTP Coupe - Rebuilt Trans, F1 Hood, Front Air Dam, and Gen 5 Blower Swap than done with modding
  4. #4 Re: Trans swapping (out in 2 hours)
    Akron Ohio
    Orange can of DEATH!!!!!
  5. #5 Re: Trans swapping (out in 2 hours)
    another hour and a half plus parts store runs. It's in, everything is hooked up except axles and subframe.
  6. #6 Re: Trans swapping (out in 2 hours)
    Add in a JY run for clips. Done, test driven and cleaned the garage. Plus took delivery of the next car/motor/trans/ic ...you name it.
  7. #7 Re: Trans swapping (out in 2 hours)
    how many bolts holding up the sub frame
    SMGPFC #77
  8. #8 Re: Trans swapping (out in 2 hours)
    GTP Level Member lambokit's Avatar
    Apr 2009
    Radford, Virginia
    Only 4 bolts holding in subframe.
    Lambokit to be built!!!!!
  9. #9 Re: Trans swapping (out in 2 hours)
    Charles City, IA
    Bill you should invest in an engine support bar, makes lining the trans up a lot easier.
  10. #10 Re: Trans swapping (out in 2 hours)
    Nick..if you notice, there's one chain going front to back on the driverside. I've got a "special tool" that i put on an exhaust stud by the EGR. Keeps it nice. Who has trouble lining it up? Sure it would be nice to have, but it's yet another thing in the garage. Who has trouble lining it up? Being on your back isn't ideal. A nice lift with trans jack and all the adjustments would be the only way to make it easier IMO.
    Owner picks it up tonight, I am on to the next one. Four Sixer's car.
  11. #11 Re: Drivetrain work (trans swap 5 hours)
    5 hours is pretty good. i think i did my first and only trans swap in my car in somewhere around 6 hours. however, i had a lift and a trans jack and stuff at my disposal.
  12. #12 Re: Drivetrain work (trans swap 5 hours)
    You didn't stop for beers..
  13. #13 Re: Drivetrain work (trans swap 5 hours)
  1. Motor and trans mount swapping
    By BillBoost37 in forum General Tech Discussion
    Last Post: 04-18-2013, 12:00 PM
  2. Few hours with my GT
    By Mousek801 in forum Visual/Body Modifications
    Last Post: 06-20-2010, 01:43 PM
  3. After 7 Hours!
    By KawaFord in forum Off Topic Discussion
    Last Post: 01-19-2010, 12:41 PM
  4. Army of Two: 40th Day in 5 hours.
    Last Post: 01-14-2010, 08:57 AM
