Thread: electric water pump (meziere)
Results 1 to 10 of 10
  1. #1 electric water pump (meziere)
    Falls Church
    Hi I just bought the electric water pump and do I need a different belt and tensioner to make it work?
  2. #2 Re: electric water pump (meziere)
    Just a different belt.
  3. #3 Re: electric water pump (meziere)
    Falls Church
    what size is it?
  4. #4 Re: electric water pump (meziere)
    Portland Oregon
    What year is your gtp? Here's a breakdown of what part numbers of belts you'll need depending on year. All model numbers start with K060....
    875 - Series II 99+ accessory belt with Meziere electric water pump
    864 - Series III accessory belt with Meziere electric water pump
    895 - 97/98 with Meziere electric water pump
  5. #5 Re: electric water pump (meziere)
    Falls Church
    its a 97, so I just go to any auto parts store or should I go to the gmc dealership to get the belt? and tell them its #895?
  6. #6 Re: electric water pump (meziere)
    Portland Oregon
    You can go to a parts place like Autozone or Oreilly's. Most belts have the same part number. The first part (060) tells you it's a 6 rib belt, the last part (895) is the individual model number for the belt. Bigger number the longer it is. If you walk into a parts place just tell em you need a 060895 serpentine belt and they'll get you what you need.
  7. #7 Re: electric water pump (meziere)
    Falls Church
    Thanks for your help bro!
  8. #8 Re: electric water pump (meziere)
    Quote Originally Posted by OH4CompG View Post
    Actually that's the length. 89.5 inches in length.
  9. #9 Re: electric water pump (meziere)
    Minnesota
    Bumping an old thread.
    Why is there a difference between the Series II and Series III belts?
    I installed my EWP with the Series II 875 belt and it seems loose.
    EDIT-
    Looks like some people are running a larger 3.5" idler pulley on the accessory belt.
    Anyone else on here had/have this same problem?
    I don't know why that chart doesn't say to use a belt a 1/2" shorter if that is correct?
    Ac compressor mounting difference.
  1. electric pump yes or no?
    By l67swap in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-17-2013, 10:37 PM
  2. Water Pump Help
    By thewaitinggame in forum General Tech Discussion
    Last Post: 02-18-2011, 07:57 PM
  3. Anyone ever have their Meziere electric WP fail?
    By 95naSTA in forum General Tech Discussion
    Last Post: 12-01-2009, 02:21 PM
