Thread: Zzp "race" battery a pita
Results 1 to 12 of 12
  1. #1 Zzp "race" battery a pita
    GTP Level Member
    Nov 2008
    MA
    ok so i needed a new battery so i figured id get a lightweight one since i dont have any aftermarket stereos etc. well the new battery comes in and i attempt to put it in but two probs arise. the battery hold down bracket doesnt work for the zzp piece since theres no lip on the new battery. ALSO the new battery has smaller holes for the terminal so i need to replace the pos/neg screws for the factory harness. idk what the track techs. deem a good enough battery hold down either so i dont want to get turned down when i get back...any suggestions? anybody use this battery?
    03 GTP - 13.8 @ 100 2.160ft
    99 GTP - DD
    *Operation Iraqi Freedom/Operation New Dawn Veteran*
  2. #2 Re: Zzp "race" battery a pita
    Jan 1970
    Maquoketa, Iowa
    It's a dry cell battery so you can put it on its side or any way you want. They have the measurements of the battery posted right where you buy it, most people who opt for this battery aren't afraid to put it in the trunk or want to make room for something else in the engine bay.
  3. #3 Re: Zzp "race" battery a pita
    GTP Level Member
    Nov 2008
    MA
    what in your opinion would be the best way to hold this battery down since i cant use the factory bracket? fab a custom one? would track techs fail me for having it zip tied a few ways? thanks for the help man
    99 GTP - DD
  4. #4 Re: Zzp "race" battery a pita
    why the hell did you buy a battery from them with a 400% markup on it?
  5. #5 Re: Zzp "race" battery a pita
    GTP Level Member
    Nov 2008
    MA
    99 bucks is a 400% markup?
    99 GTP - DD
  6. #6 Re: Zzp "race" battery a pita
  7. #7 Re: Zzp "race" battery a pita
    GTP Level Member
    Nov 2008
    MA
    7.05" long, 2.95" wide, and 6.55" high (without terminals)
    ZZ Performance
    99 GTP - DD
  8. #8 Re: Zzp "race" battery a pita
    meh, it's okay. for $99 it isn't bad considering that it isn't meant to do anything, but start the car.
    in comparison to a normal car battery the specs aren't all that special, but in your case it'll get the job done.
  9. #9 Re: Zzp "race" battery a pita
    Jan 1970
    Maquoketa, Iowa
    Multiple ways, but here's a few ideas:
    Stealth 316 - Battery move to rear compartment
  10. #10 Re: Zzp "race" battery a pita
    Waukesha, WI
    check out jegs, summitracing
    RayRay
    92 Turbo miata
    71 bagged lemans wagon
    02 lexus is300
  11. #11 Re: Zzp "race" battery a pita
    Jersey
    i bought that zzp battery. Never used it, still sitting in the box. I use a duralast gold top
    16' wrx sti- stock
  12. #12 Re: Zzp "race" battery a pita
    Waukesha, WI
    interstate
    RayRay
    92 Turbo miata
    02 lexus is300
  1. "abs" and "trac off" lights staying on?
    By john9472 in forum Brakes/Suspension/Chassis
    Last Post: 12-03-2013, 09:38 PM
  2. Chug at start, "bouncing" tach when key turned to "on"...
    By KZOO3800 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-21-2011, 10:50 PM
  3. "CHECK GAGES" And Battery Light?
    By K7Gixxer750 in forum General Tech Discussion
    Last Post: 11-22-2009, 04:16 AM
  4. "Check CD" or "error reading cd"
    By pontiacprincess in forum Audio, Security & Visual Electronics
    Last Post: 04-04-2009, 08:22 PM
