Thread: Intake choices, new ideas...
Results 1 to 20 of 22
  1. #1 Re: Intake choices, new ideas...
    ^^Followin' off that...
    Back in the old days for cheap intakes...guys would gut the airbox and open up the front of it as well...worked pretty good from what I remember...and they ran a solid tube to the TB instead of the rubber corrugated junk.
  2. #2 Re: Intake choices, new ideas...
    MI
    There has been discussion on this forum for a while about whether or not the stock setup was really that restrictive. K&N provided me some pretty hard data to back this up. The bottom line here is that the engine max CFM at 6000 RPM is 451 while the K&N panel filter can provide 592.4 CFM, the airbox restricts flow to 240 CFM. So the running while breathing through a straw analogy applies. Just thought I would pass this on.
    "Thank you for your interest in K&N products. A stock engine usually has a volumetric efficiency in the high 70% to mid 80% range which would put the CFM of your motor at 451 CFM at 6000 RPM. That is the maximum amount of air that your engine car draw in so, even if your use a filter that can flow 800 CFM, your engine will still max out at 451 CFM and there won’t be any performance gain.
    The CFM of a filter is based on its surface area and our 4 layer cotton filters flow around 6 CFM per square inch. Horsepower gains from the intake system are primarily from designing a more efficient and smoother intake tract. As you can see from our air flow test data, our panel filter can flow 592.4 CFM on its own, but in the stock, restrictive airbox, it can only flow 240 CFM.
    http://www.knfilters.com/dynocharts/33-2334.pdf
    By eliminating the airbox and using a smoother intake tube, the efficiency increases and the CFM capability of the system is greater than the requirements of the engine.
    The only benefit of using a filter that flows more CFM than your motor needs is that it extends the service life because there is more surface area to draw air through before the filter becomes clogged. With that being said, a twin intake will provide no performance gain and will only be for aesthetic purposes. "
  1. if anyone needs intake ideas...
    By DaytonaGTP in forum General Tech Discussion
    Last Post: 05-13-2010, 07:13 AM
  2. So many choices... what do u guys think???
    By rlvis361 in forum Tires & Wheels
    Last Post: 05-10-2010, 09:59 PM
  3. PLOG choices
    By jersey jok3r in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-05-2009, 01:00 PM
  4. GXP Rim/Tire Choices
    By Feather Head in forum Off Topic Discussion
    Last Post: 10-26-2009, 02:59 PM
  5. cam choices
    By popeyenate in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-29-2009, 08:17 PM
