Thread: L67 swap not running right
Results 1 to 9 of 9
  1. #1 L67 swap not running right
    SLP, GTP or call it MUT! thunder71173's Avatar
    West Frankfort Illinois
    I just got done working on my GP and it seems as though the BBV valve isnt functioning properly. I ordered the BBV actuator from ZZP and installed it and it is still not opening all the way up and the car runs very slugish and gets really crappy gas mileage? I havnt changed th sulenoid on the BBV yet but has anyone else had this problem with the boost not going full and fluctuating? It also runs really sluggish on the botton end until you really get on the gas and when you do the boost gauge flashes back and fourth in the middle of the guage and that is all the boost I am getting and I am running a ported blower and 3.4 mps?
  2. #2 Re: L67 swap not running right
    if the BBV isn't closing then that would cause some issues.
    Disable it by leaveing both vacuum lines off of it and cap both of the hoses off.
    leave the BBV actuator open to atmosphere.
    If the car drives mostly normal then its either the acuactor or the bore for the BBV is dirty and causing it to stick.
    I never had any boost issues with that case.
  3. #3 Re: L67 swap not running right
    So its ok to leave the bbv un hooked? Wont it be getting boost at idle then?
  4. #4 Re: L67 swap not running right
    It won't make boost for a while.
    However, this will kill some fuel economy.
    Unsure if that is a concern.
  5. #5 Re: L67 swap not running right
    I unhooked the BBV sulenoid and the monster came to life! I will have to get a new sulenoid as gas mileage is a major concern.
  6. #6 Re: L67 swap not running right
    The solenoid being the thing with the wire and vacuum lines going to it right?
    Because thats for traction control and the speed limiter
    As long as you turn of trac every time you get in the car you'll be okay.
    But i seem to recall that being something you didn't want...
  7. #7 Re: L67 swap not running right
    It seems to run fine without bothering the trac control but i will do it anyway until i get a new sulenoid.
  8. #8 Re: L67 swap not running right
    It'll be fine until trac kicks in.
    then you'll go very lean....very bad.
  9. #9 Re: L67 swap not running right
    ah I will just stay off the gas til I get it fixed then. Dont plan on doing many burnouts anyway tires are too expensive. However I do have my GTX wheels in the process of bieng re coated.
  1. Anyone running these?
    By IMPALADAKID in forum Tires & Wheels
    Last Post: 01-06-2011, 07:17 PM
  2. Top swap NOT running right.
    By Pure2sin in forum Engine
    Last Post: 12-10-2010, 10:01 PM
  3. GTP Running Rough.. few new parts but still not running right.. HELP
    By azmattaz06 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-29-2010, 02:34 PM
  4. well, got the car running after swap, but....
    By NineD9GT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-07-2010, 07:17 PM
  5. Swap= not running, misfire
    By nxgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-27-2010, 02:11 PM
