Thread: RWD grand prix
Results 1 to 20 of 28
  1. #1 RWD grand prix
    Banned
    Apr 2011
    wv
    so ive heard a lot of dribble about converting a grand prix to rear wheel drive. whats the simplest way to achieve this? i was thinking that putting a grand prix body onto an f-body chassis would be simple enough. can that be done?
  2. #2 Re: RWD grand prix
    Nov 2008
    Waterloo, Iowa
    Custom rear axle, thousands of dollars in it, etc.
  3. #3 Re: RWD grand prix
    Never Never Land
    there is a guy on fullthrottlev6 that did it...ill see if i can find the link.
  4. #4 Re: RWD grand prix
    its called a G body.
    invest in one, you'll be pimping, but the monte guys will look better doing it.
    hell even the regals look better. (not to mention the GN's...)
  5. #5 Re: RWD grand prix
    Never Never Land
    wow i found that a lot quicker than i thought i would. RWD Grand Prix
  6. #6 Re: RWD grand prix
    Banned
    Apr 2011
    wv
    well i dont care about converting a grand prix to rwd. thats too much effort and too many things can go wrong. im talking about a complete chassis swap. something short of welding up a tube chassis.
  7. #7 Re: RWD grand prix
    Nov 2008
    Waterloo, Iowa
    Simple answer is no, you cannot put it on an Fbody chassis. Nuff said.
  8. #8 Re: RWD grand prix
    Banned
    Apr 2011
    wv
    ok simple question. is there any chassis that you can put it on? f-body was just an example
  9. #9 Re: RWD grand prix
    Nov 2008
    Waterloo, Iowa
    No.
  10. #10 Re: RWD grand prix
    Banned
    Apr 2011
    wv
    im certain theres a way to adapt it to another chassis
  11. #11 Re: RWD grand prix
    Nov 2008
    Waterloo, Iowa
    Nope.
  12. #12 Re: RWD grand prix
    Banned
    Apr 2011
    wv
    whatever. how about someone who knows what theyre talking about?
  13. #13 Re: RWD grand prix
    Its unibody... you' can't do ****.
    HOWEVER........
    I dont know anything about a single thing.
  14. #14 Re: RWD grand prix
    Nov 2008
    Waterloo, Iowa
    So not you then.
    But if you think you can do it go ahead. What chassis are you going to use?
    The thing is a unibody, so good luck with that.
    Edit: Matt beat me to it.
  15. #15 Re: RWD grand prix
  16. #16 Re: RWD grand prix
    ^^Your point makes too much sense; guy.
  17. #17 Re: RWD grand prix
    Banned
    Apr 2011
    wv
    too bad the camaros are so piss ugly. i want a rwd gp
  18. #18 Re: RWD grand prix
    North Jersey
    Quote Originally Posted by L36pro View Post
    who gives a ____ what it looks like when you would only need the chassis...
    and believe me, i'm pretty sure no ones wanted to make a FWD car RWD more then me. it would be worlds easier not to 'swap' chassis and just use the driveshaft, transmission, rear end, SOME linkage, and computer if you were doing a manual swap, hell if your gonna do all that, might as well get a SS/Z28 or a Trans Am donor car and make it an LS1 6sd, i mean if your going to have all of that out, might as well go for broke.
  19. #19 Re: RWD grand prix
    Waukesha, WI
    go on pro-touring.com a guy did that swap he took a unibody car (lexus), and cut everything down to the strut aprons the floors and the wheel tubs. then said guy grafted a volvo? body onto said chassis.
    its doable the floor section needs to be supported so it doesnt fold like a taco. i love how no one will take a shot at this kinda project. i had thought about buying a Chris alliston chassis (1500$) grafting in f body running gear then cutting up a donor gp body and zeus fastening the pieces on. nascar style.
    seriously get on protouring.com they do crazy ****
    RayRay
    92 Turbo miata
    71 bagged lemans wagon
    02 lexus is300
  20. #20 Re: RWD grand prix
    Nov 2011
    Bloomington IL
    Im looking at using parts from a CTS-V. I have a 2005 gtp and theyre fractions of an inch off. So itll take some fab work but easiest is a CTS V6 (the V8 requires a lot of strengthening) turbo it and use a 6spd tranny (you have to open up the housing). Run the driveshaft through the exaust channel and have either a side exaust or do more fab work to run duelies. The shop I talked to said its totally doable, only thing is cost. For them to do it would cost 20k-30k. But most of that labor. If you know your **** then itll be cheaper and faster (and better looking) than most cars for that cost
  1. Grand prix GT side skirts on 97 Grand Prix SE
    By Carnes97SE in forum How To Write-Ups/Tech Tips
    Last Post: 11-17-2013, 05:17 PM
  3. Grand Prix GXP exhaust on a standard Grand Prix
    By JenniGP in forum General Tech Discussion
    Last Post: 03-29-2011, 10:15 PM
  4. Will a 04 grand prix 3800 engine fit into a 01 grand prix
    By jordan61488 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-24-2010, 01:01 AM
