Thread: Leak behind throttle body
Results 1 to 3 of 3
Chibitodd Leak behind throttle body 04-18-2011, 01:44 AM
BillBoost37 Re: Leak behind throttle body 04-18-2011, 07:47 AM
matt5112 Re: Leak behind throttle body 04-18-2011, 10:42 AM
  1. #1 Leak behind throttle body
    Apr 2011
    Modesto ca
    I have a nasty leak after my throttle body. I have a 97 gtp with a 3 bolt throttle body. The sc should take a 4 bolt. I have an adapter plate. It won't seal. I have block sanded the front and back to make sur it's flat. I replaced the 3bolt gasket and made a 4 bolt gasket. I used Indian head gasket sealer and it held for 2 days.I tried silicone and new gaskets, lasted about 10 min. I used only silicone and leaked. I need to smog the car and cant be driving with a lean condition. Please help. The sc to intake gasket had to be made as well. Lower intake is ported and inch on he passenger side. Any ideas? In Modesto ca thanks , Todd
  2. #2 Re: Leak behind throttle body
    A stock factory car will not have an adapter or a 4 bolt TB. That sounds like you have a Gen V or a TB spacer.
    Please elaborate on which you have.
  3. #3 Re: Leak behind throttle body
    Moved.
    Try to post in the appropriate section.
    It helps others find your question and others find the answers later.
  1. Throttle body
    By JAllegar in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-18-2011, 06:01 PM
  2. LS1 Throttle Body
    By JbrownGTP in forum General Tech Discussion
    Last Post: 07-05-2009, 07:14 PM
