Thread: whats the proper name???
Results 1 to 6 of 6
  1. #1 whats the proper name???
    GTX Level Member 94grandprix's Avatar
    Jul 2010
    Crandall, Georgia, United States
    ok,after we gotn done doing our intake gaskets ,we now discovered the top piece that says 3100 is cracked a little,whats that piece called because autozone cant find anything under intake cover or anything.
  2. #2 Re: whats the proper name???
    Florida
    That's your Upper intake manifold.
    Autozone wont have that. Your best bet is to go to a junkyard/u-pull it and grab one. Shouldnt be but $10-15.
  3. #3 Re: whats the proper name???
    Jul 2010
    are you sure that what its called because i just pulled up upper intake plenum manifold
  4. #4 Re: whats the proper name???
    GT Level Member Deviq's Avatar
    SE WI
    Describe the piece for us or take a picture. Kinda hard to know exactly which one without more info. Are you talking about just the plastic engine cover? Is it metal? Do any wires or vacuum lines run into it?
    Quote Originally Posted by zildjian102
    .. friggin trashy people. I did stuff with their daughter
  5. #5 Re: whats the proper name???
    Jul 2010
    its not a 3.8 its 3.1 liter and yes vacum lines,air box and other stuff runs to it and its whats in plain view when you pop up the hood it says 3100 sfi and yes it metal
  6. #6 Re: whats the proper name???
    Ohio
    that would be your plenum
  1. Z7 Turbo Kit and proper boost
    By ARFF22 in forum Turbo
    Last Post: 03-10-2011, 03:20 PM
  2. what are the proper oil pressure readings
    By Scottydoggs in forum General Tech Discussion
    Last Post: 09-02-2010, 06:11 PM
  3. Proper way to seafoam 04+ S/C?
    By dirtmaster88 in forum 04+ Specifics
    Last Post: 01-11-2010, 04:32 PM
  4. Proper Alternator to purchase for 04 GT2
    By proofinlife in forum Audio, Security & Visual Electronics
    Last Post: 07-04-2009, 11:48 PM
  5. Proper gap for plugs
    By Clar2478 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-06-2009, 08:15 PM
