Thread: Headers/Exhaust....point me in the right direction
Results 1 to 8 of 8
  1. #1 Re: Headers/Exhaust....point me in the right direction
    Orrrr ya could just pick up the parts you need to connect it .....ahead of time.
    The headers you have in your hand, so finding out if it's 3inch OD or ID is really easy. You likely can't find a reducer to the stock 2.25inch size pipe from a 3". Some exhaust shops will make one for you super cheap. But that's a large difference. Another idea is to get two adapters. From 3 to 2.5, then 2.5 to 2.25. A couple of clamps and some planning and it'll be fine until you get a different catback or have more work done.
    One of the three installs the other week had this issue. An extra 30 min of parts hunting and it was cleared up.
  2. #2 Re: Headers/Exhaust....point me in the right direction
    SE Level Member ElAlacran2010's Avatar
    Dec 2010
    El Paso, Texas
    Well I just removed my stock manifolds. Got everything prepped to put in the new headers. Except yeah i need to cut the pipe now since i removed the flange. I decided to go with straight 3'' pipe no cat. Im gonna reduce after the O2. Thanks BillBoost for the idea to reduce from 3'' gradually to the stock pipe size. I just hope i can deal with that catless exhaust sound. If not i guess im gonna buy the cat ASAP! Broke but content....
  3. #3 Re: Headers/Exhaust....point me in the right direction
    That works. Keep in mind that dropping the back of the subframe allows you to wiggle the rear header into place. Get it held on and then lift the subframe, mark where the O2 will hit on the tunnel edge. Pull the header back out and make the firewall/tunnel edge move and put the header on for good.
    Coming from the Bonneville world is nice because nothing was made for that car. There's no catback flanges to bolt up to.. it's all make your own, think outside of the perfect situation box and come up with solutions.
    When someone says can't, my mind starts to think and look at the problem. There's an answer for every question, the challenge is finding it.
  1. Exhaust flange gasket direction???
    By 03GTPLE in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-12-2010, 07:53 AM
  2. gtp modding direction
    By eddyman in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-28-2010, 05:24 AM
  3. Oil leak exhaust headers
    By bbptech in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-16-2009, 08:33 AM
  4. Movement in the other direction!
    By GPGT08 in forum Tires & Wheels
    Last Post: 07-01-2008, 05:06 PM
