You don't. It's the axle nut 36mm stock size, 34mm if it's been replaced.
The axle will give you the 1/4" wiggle room w/o taking the nut off. Why remove/loosen anything you don't have to? The three bolts I'm talking about are 1/2" technically or a loose 13mm and they hold the hub to the knuckle.
