Thread: Need to replace Ignition Switch
Results 1 to 9 of 9
  1. #1 Need to replace Ignition Switch
    Lifer h0wl0ngcanitbe's Avatar
    Marysville WA
    So my heater, DIC, and my head lights are not working properly. They flip on and off with a mind of their own. Ive looked through enough threads to figure out that I need to replace the Ignition Switch but didnt find a DIY thread about it.
    Is this an easy process to replace the Ignition Switch? Ive heard of alot of guys doin this so it sounds easy enough. If anyone knows of a good walk through that would be great thanks!
    2001 4dr Black GTP Stock and staying that was... maybe
    1997 2dr Black GTP Open Cone, GXP Rims, Black Headlights, ZZP Headers, ZZP Cat Back, Bunch of suspension parts from ZZP, ZZP 10.5MM plug wires, Autolite 605s, Overkill Tune
  2. #2 Re: Need to replace Ignition Switch
    long and skinny is.. Park in a Sears parking lot (for easy access to tools ).
    Pull the shroud off the column. Find the wiring for the igntion switch and remove it at the base of the column with a 7mm. Tie fishing line or string onto it. (to pull the new one back through the maze) Look at the worlds smallest torx head bolts and go buy the right size, cause it's friggin small. Pop those two off and one other set of wires, uh soleniod to rellease the key wires..yeah. Pull the connector up through the column and tie the string/line onto the new one. Reverse process to install.
    Nope, honestly never done one.
  3. #3 Re: Need to replace Ignition Switch
    Marysville WA
    Heh thanks for that walk through man!! Ill post up on the results and let ya know how it goes ill try to take pics too and show future dudes.
  4. #4 Re: Need to replace Ignition Switch
    GT Level Member Vegas~Blown's Avatar
    Aug 2008
    vegas
    you've got to get the lock cylinder out. not hard as long as you know what to do. also, and this is big --- don't take the key out of the lock while it's out or you're screwed.
    think it's on cgp where there's a great write up. might be here though? it's a ticky, where ever it is.
  5. #5 Re: Need to replace Ignition Switch
    why does the lock cylinder come out? I've never seen/heard of that being touched since the switch is a different and seperate piece.
  6. #6 Re: Need to replace Ignition Switch
    Found the thread and understand why you said pull the tumbler. It's because some guys remove things that don't need to be removed. aka excess work for the same end result. I was able to work around the tumbler w/o needing to pull it out.
  7. #7 Re: Need to replace Ignition Switch
    Aug 2008
    vegas
    something that's not unique to the ignition switch..... there's times I just shake my head at all the extra work I see folks describing.
  8. #8 Re: Need to replace Ignition Switch
    Apr 2011
    up state ny
    Quote Originally Posted by h0wl0ngcanitbe View Post
    I'm having the same issues with a 2000 GP, here are two links that another member of this forum sent me.
    This link covers the trouble shooting to determine your next move.
    Sparky's Answers: 2002 Pontiac Grand Prix Blower Inoperative, Erratic
    This is the link for replacing the switch.
    Sparky's Answers: 2002 Pontiac Grand Prix, Changing The Ignition Switch
    Good luck, I'll be attacking this soon as well.
  9. #9 Re: Need to replace Ignition Switch
    Marysville WA
    Thanks for that man!
  1. How to replace the ignition key?
    By regalls in forum Audio, Security & Visual Electronics
    Last Post: 04-18-2011, 01:09 AM
  2. ignition switch help
    By redrivergar in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-02-2010, 09:13 PM
  3. ignition switch
    By mtz956 in forum General Tech Discussion
    Last Post: 08-10-2010, 04:53 PM
  4. Replies: 1
    Last Post: 02-01-2010, 10:18 AM
