Any one own or heard anything about these fuel rails?
PRJ Performance Gen3 L67 Aluminum Fuel Rails Kit: 3800 Performance
or
ZZ Performance
or
ZZ Performance
From what I've read PRJ is the way to go. ZZP's have had issues with the FPR, not sure if they are corrected or not.
Dont know what your mod list is. They're usually for an intercooled setup. But I'd stick with 3800 performance, as zzp has failed me in the past.
I see no reason it wouldnt, the injector bungs are in the same spots in the Gen V intake manifold as they are in the Gen III.
I've worked with both and owned PRJ rails. It's not a question, the PRJ rails work great, fit great and never give an issue. The ZZP rails have a pile of issues that start off with how they are held down to fitment and each possible issue you can think of.
ZZP rails suck. Mine leak every 3 months
get PRJ's without the FPR adapter then get an aftermarket one.
Yeah you might have to trim some of the bracing under the hood.
Nope, not motor mount, the actual hood.
If you pop the hood, and look at the underside of it, theres bracing in the middle, you might have to trim some of that to clear.
You might also run cradle spacers, if you only need to make up a tiny bit of clearance....but I really dont like that idea...doesnt seem safe to me.
The metal framework of the hood. I dont believe the SD hood has an actual cross brace, so you should be okay.
But the only good way to tell will be to install everything, and try to close the hood. Do it gently, and if it clears, it clears...if not, you'll need to trim the inside of the hood to clear.
XD, I'd love it. Be nice to wrench on a GTP again...mines been sitting heartless for a few months now...
